I am thinking about doing a major overhaul of the Scoob to keep it going strong for another 200,000mi (I just rounded 180,000 this week!). Part of the plan is a complete transmission rebuild along with a slew of other very costly and hardly practical ideas.
Any suggestions on where to get my rebuild kit? I am talking all frictions/steels, seals, gaskets, solenoids, etc. I don't anticipate any hard-part failures but I will naturally measure clearances and replace as necessary.
Car: 1994 Subaru Legacy non-turbo 2.2l engine 4spd auto.
I suppose if you suggest some good upgrades I could implement those as well.
Good source for auto trans rebuild kit
~R-Inge
1994 Legacy L Wagon, N/A Spruce Green.
Well, if your budget isn't to tight, then i would get a rebuild done by a dealer, i can NOT recommend a transmission shop, as they i have NO trust at all in ANY transmission shop ever! I think my dealer told me about $3000CDN for a FULL rebuild.
Just wondering though, are there any issues with your transmission as off right now?
I would do the work myself. I'm a mechanic, though transmissions are not my forte.ericem wrote:Well, if your budget isn't to tight, then i would get a rebuild done by a dealer, i can NOT recommend a transmission shop, as they i have NO trust at all in ANY transmission shop ever! I think my dealer told me about $3000CDN for a FULL rebuild.
The car doesn't have any problems really...the AWD hesitates to engage under hard throttle, so it tends to spin the front tires in the ice if I get on it too hard off an intersection, but I image the transfer clutch is in rough shape as I had a pretty bad shudder, and it still hasn't gone away, though it lessened a bit with a BG tranny flush last year.
I think I may just rebuild the transfer clutch, replace my solenoids, and perform any available updates to the valve body that might improve line pressure and shift quality.
~R-Inge
well, in that case i suggest u get the new updated rear housing, come with solenoid clutch everything and updated design to hit torque bind, from wear and tear, not from uneven tires. See how much a dealer will quote u for all the parts.
Yeah, I'll do that. I didn't realize there was an updated rear housing.ericem wrote:well, in that case i suggest u get the new updated rear housing, come with solenoid clutch everything and updated design to hit torque bind, from wear and tear, not from uneven tires. See how much a dealer will quote u for all the parts.
I do know that the previous owner had some work like that done to it for a much more serious issue, which involved r/r the rear housing, but I don't know if it was the updated one, and I especially wonder since it has the bind issue these days.
~R-Inge
legacy4ever
check out this site:
http://www.importperformancetrans.com/subaruauto.shtml
Ben
93MY EUDM Legacy EJ22
