How to make it fit???
I have a set of 04' WRX wagon springs sitting in our shop. Will they work with stock SS struts and tophats? Would this be a good/cheap setup for auto-X? I only want the lower the car about 1-1.5 inches in front and .5-1" in the back.
Any input/help/suggestions is greatly appreciated.
91 SS -Carbon Bronze Pearl
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
91 Rio Red SS- RallyX Project
93 AWD Sedan- FOR SALE!
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
hey Nick, they are stock 04 WRX springs. We've had them since this summer. I just need something cheap, and before March to get the car lower and handle a little better.
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
No they won't, no he doesn't.555BCTurbo wrote:Are they factory springs Devan?
If so, they will actually lift your car...
To make them fit I think you will need 1991 Non-Turbo rear tophats...
They'll fit fine and lower the car slightly.
livestrong did you read the thread titled "04+ impreza rear springs on 1st gens?"
I am pretty sure that all of the Sport Sedan springs were not tapered, even 91's, and therefore do not have tophats for tapered springs...therefore requiring the hats off an NA car...
Read: "converting to later model strut assemblies
If you have a....And want strut/spring combo......Then you need
90-91 AWD....GC/GM/GF (93-2001impreza)........FP, RP
.......................GD/GG (2002+ Impreza)................FP, RP, SPT
.......................BD/BG (95-99 legacy)....................FP, RP
.......................BE/BH (2000- legacy)....................Probably FP, No fit rear!
.......................SF (98-02 forester)........................Probably FP & RP
.......................SG (03- forester ...........................Probably FP & RP
.......................BC/BF fwd.....................................Struts Don’t Fit! "
As far as lifting the car...remember that his car has around 135k miles on it, and the factory springs would have sagged...therefore, using the 04 springs would lift it just because they have less miles and consequently less wear on them... I have seen pictures and read threads of SS owners who put WRX springs on their cars and measuring them to ride higher...
I could be partially wrong, but consider these points before you go discounting everything I say...
Possibly, but I don't think there is a difference between turbo and n/a spring diameters. Also that section of the compendium you posted doesn't differentiate between 02-03 and 04+ Impreza springs.555BCTurbo wrote:I am pretty sure that all of the Sport Sedan springs were not tapered, even 91's, and therefore do not have tophats for tapered springs...therefore requiring the hats off an NA car...
Either that or I've been giving a lot of wrong advice...
jamal wrote:Possibly, but I don't think there is a difference between turbo and n/a spring diameters. Also that section of the compendium you posted doesn't differentiate between 02-03 and 04+ Impreza springs.555BCTurbo wrote:I am pretty sure that all of the Sport Sedan springs were not tapered, even 91's, and therefore do not have tophats for tapered springs...therefore requiring the hats off an NA car...
There absolutely is a difference between Turbo and NA spring diameters...
90-91 Legacy Non Turbo cars had tapered springs
All turbos have normal non-tapered springs (same as 02-03 WRX ones)
92-94 had the normal setup like the turbos
I believe the reason that it does not differentiate in the compendium is that for 90-91 cars you need tophats and whatnot regardless of what year the WRX springs came from
- quasi-mod-o
Incorrect sir. All 90-91 Legacies have tapered rear springs. I have a set of brand-new 91 Turbo specific rear springs sitting at my house right now that are definitely tapered.555BCTurbo wrote:All turbos have normal non-tapered springs (same as 02-03 WRX ones)
Sorry Nick, you're striking out555BCTurbo wrote:If so, they will actually lift your car...
Will 04 WRX Wagon springs Raise or Lower my car????
If it will lower it, how much??????????????
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
