spacer plate
spacer plate
I have been thinking of getting some spacers to make my tire base wider.... what do u guys think? good bad what are some of the up and downs of this. Im running stock tires
|====.[Legacy. Central].====|
|=+[Leaving A True Legacy]+=|
Manarius
Re: spacer plate
Bad. Spacers put more stress on the bearing/hub assembly. Bearings don't like having weight put on them unevenly. Therefore, they'll burn up a lot faster than normal. Just get wider rims/tires if you want a wider wheelbase.Carbix wrote:I have been thinking of getting some spacers to make my tire base wider.... what do u guys think? good bad what are some of the up and downs of this. Im running stock tires
