EDM E-Code '92-94 Headlights
Got a new part? Is it the best thing you've ever seen? Is it a complete ripoff? Let us know about your parts and service.
farfrumwork
Post by farfrumwork »
So I was lucky enough to win a pair of *barely used* EDM E-Code headlights off ebay (from a board member). These lights are in near perfect condition! :shock:
Here are some pics in the garage just after I got them in
ewwww, old usdm lights
mmm, E-code
Before I installed the E-codes, I went out and got some shots of the stock USDM lights. They have 89kmi, some pitting, but are relatively clear (not yellow anyhow). I'm also running Osram 65/70w bulbs.
After some quick adjustments (they are not perfect, but I'll fiddle and get them where I like them soon enough) I reproduced the original photos (of stock lights) with the e-codes.
Enjoy---
Stock 25' from garage
Edm 25' from garage
Stock 25' from wall
EDM 25' from wall
Now, the above photos are on the point and shoot mode, but the following shots were taken in manual mode with exactly the same shutter speed, fstop, and whatnot. I marked a spot in my street so the car was in the same spot as well.
Stock 100', manual mode
EDM 100', manual mode
I think the pictures speak for themselves. I am very pleased, and can only imagine that it'll get better once I aim things a bit more. They do throw a relatively narrow swath of light, but it's not a pencil beam or anything that severe (not much less than stock). Some fogs may help in that dept some day...
A harness is next, to try to get even a bit more outta the things. And I'll be wirring the city lights to run off the parking lights soon too - that'll be tits!
-Chad
Old - '93 T-Leg - 14.693 @ 92.68 at 5800ft ASL (Bandimere Speedway)
New - 07 Spec B/stg 2
"bloodstains - speed kills -fast cars - cheap thrills -rich girls - fine wine
i've lost my sense - i've lost control - i've lost my mind" Agent Orange
Yeah....I was very impressed with the EDM lights.
The light cutoff is much more sharp. In addition, the amount of light they throw directly in front of the car and to the cutoff point is A LOT better.
I did a relay setup with mine & hooked them directly to the battery......you'll like the results!
It's cool having the city lights :)
Definitly a improvement, but try some silverstars, and make the lights aim a little higher. Then it will be substantually more bright, still didn't look much brighter them my stock headlights to be honest. :?
farfrumwork
I can't wait to get a relay harness, I know there is some voltage left on the table as the stock connectors are really fugly. I should take some quick measurements to see where I sit today...
And it's hard to get good pictures of light output, that's why I took some manual mode (to try to control how the shot is metered by the camera). But there is a LOT more light being thrown on the ground than with the stock lights, you can clearly see it in the pics above (look at the forground between stock and EDM 8) ). And the cutoff is nuts, it throws a wall of light way out into the distance where the stock units light just faded into nothing.
Other than that, yes the lights were a smidge low at the time of photos. They probably need a bit of L/R adjustment too.
But no, Silverstars will not be brighter than the overwattage Osrams (high beam wattage on low beam filament) that are in there. I have some Phillips Vision Plus I could put back in as an experiment, but these Osrams have more output - period.
Yes....silverstars suck.
IronMonkeyL255
Post by IronMonkeyL255 »
I can't wait until I get my lights.
My uncle managed to score me a set off of a friend from europe. I may soon have a comparison between stock '91 lights and '91 EDM lights.
Rio Red '91 Legacy SS
def09
Post by def09 »
Did they come in Subaru boxes? If so what were the part numbers?
farfrumwork
Yes they came in the original Subaru boxes - 8)
"Part numbers are 84004AA200 and 84004AA210."
Copied from the original owners post in the for sale forum.
klaxed
Re: EDM E-Code '92-94 Headlights
Post by klaxed »
farfrumwork wrote: ewwww, old usdm lights
mmm, E-code
-Chad
rofl over the usdm. I hate my lights. they are teh suck. going to have to pick me up some e-codes.
Brent
'92 Legacy Wagon Winestone, 265K on body, ~100K on engine, 5spd, kyb gr2's w/ whiteline ground control springs, sti top hats, hatch spoiler to be added soon...
Adam West
Post by Adam West »
How hard was the install - direct fit? Any spacing issues?
farfrumwork
bolted right in. No issues at all.
after several months now, I can say that these lights rock!
mgjs1
Post by mgjs1 »
I have a present (and quick) need for headlamps - my car just failed VA inspection for bad adjusted / unbracketed headlamp in a front left slightly wrecked corner (after passing for the past 5 years with the same headlight).
Anyway, would LOVE some of these E-code's and the Osrams. Can anyone recommend a way I could lay my hands on either / both ASAP? My 15 day pink-slip starts ticking tomorrow!
Thanks,
Matt
mgjs1
Post by mgjs1 »
The model name or SKU/part number for the best and brightest Osrams would be great - I see:
Osram/Sylvania Headlight Bulb (standard) - $10
Osram/Sylvania Halogen - SilverStar (avoid?) - $24
Osram/Sylvania Halogen - Cool Blue - $17
Osram/Sylvania Halogen - XtraVision - $15
They all say 65W.
http://www.circlestickers.com
jamal
Vendor
Vendor
Post by jamal »
The best osrams are the silverstars.
Sylvania silverstars are different and tinted, which is why they suck. Anything with "cool blue" or "the look of HID," or "100w equivalent" just means that they're tinted to look better but are not actually brighter.
Xtravisions are the next best thing you can buy in a parts store.
If you want the Osrams, e-mail Daniel Stern. He sells them or their equivalents (ie Narva Rangepower +50).
I also can't stress enough how important good aim is. The above EDM lights are aimed too close together.
go here to buy those lights and learn more about lighting:
http://www.danielsternlighting.com
farfrumwork
Yeah, these shots were the night I installed them. They have much more spread now (the drivers light is more straight) and I aimed them up a bit too. It vastly improved the light on the road.
I'm sure they could use a bit more tweaking... I'll get back at that now that it's coming into winter and I've have more darkeness to contend with.
farfrumwork
as for the Osrams, these are the 70/65 Hyper bulbs (not DOT - came from Europe) all DOT lights will say 65w, but that's the high beam - these are 65w Low/70w High.
see my review and a couple pics here:
http://bbs.legacycentral.org/viewtopic. ... ight=osram
if that doesn't work search for osram in the electrical section.
I had these as a first step toward better lighting and they do throw more light out than stock - and I've tried a bunch of "good" bulbs, not any HID wannabes...
MiataPaul
Post by MiataPaul »
are these glass or are they plastic? I might be willing to pay some money for the E codes as that is what I run in all my non subies. If they are glass then they could run much brighter bulbs. As I understand it heat is the biggest factor preventing higher wattage bulbs.
Post by 555BCTurbo »
Yes...they are glass
smh0101
Post by smh0101 »
How are the high beams?
smh0101
Post by smh0101 »
anyone?
farfrumwork
Honestly I don't know... haha
I know this is weird, but I have not had high beams on this car for 3+yrs now. Somthing is whack with the combo-switch and it turns on the high beams randomly so I pulled the leads on the H4 connectors.
I keep planning on getting a used switch, but seem to find other uses for my time/money - and yea I know, I REALLY should have high beams for safety reasons. But it is fairly rare that I wish I had highs (not out in the middle of nowhere that often as lame as that is), especially with these EDM's.
I DID get the city lights hooked up though :)
Wired them to the parking lights - it's cool.
anyone have a spare combo switch for cheap? haha
smh0101
Post by smh0101 »
one name... Blackbart
for the switch i mean...
