Devan's 91' SS!!! (*Updated June 5th! Auto-X Video!!*)
You've got a nice parts list, and you got some good deals too. Any particular reason you want to install the turbo timer? Seems like more work than it's worth.
I've got that same evo intercooler. I picked it up from a guy who had an eclipse, he said it was off a evo 3. I'd be interested in seeing how you plan on installing it, I haven't decided what I'm gonna do with mine yet.
SUBARUEHS Racing
Yeah, I'm not too sure if I will be installing it or not. I think it would be great to have a Frontmount in general. Just takes a lot of time to fab up and still keep my ABS, Power Steering, and AC. I will probably get something fabbed up this Summer.
91 SS -Carbon Bronze Pearl
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
91 Rio Red SS- RallyX Project
93 AWD Sedan- FOR SALE!
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
Thanks Nick. We might install it. It depends on how much time we have though. I really appreciate your offering to help man. We need all the help we can get. I can't wait for Auto-X and Drag season to start up!555BCTurbo wrote:I still say don't bother with the turbo timer Devan...
But it's your car...a very nice one at that!!
I will be there for sure over spring break to assist with makin' your SS haul some ass.
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
Intruding to support Nick -- the Subie coolant tank makes the turbo timer redundant.
Better to put the money into go-fast-stuff.
Re: Devan's 91' SS!!!
What did you have to source to install that TMIC? I have an 07 WRX TMIC in the garage waiting to get installedlivestrong14 wrote:
[size=75]91 Perl White 5MT Legacy Sport Sedan[/size]
Well, since I have an EJ20G swap to go with it, the coolant overflow tank is already relocated. Other than that, it is pretty much a direct bolt in. It will still require a little bit of modification to work perfectly with your turbo. What turbo are you using? I am using a 90 Degree VF8.
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
I'm using the stock RHB5. It looks like it'll be close, but not quite enough, to connect to the compressor output. Working on finding a replacement coolant tank, I learned that lesson on my last Legacy Turbo.livestrong14 wrote:Well, since I have an EJ20G swap to go with it, the coolant overflow tank is already relocated. Other than that, it is pretty much a direct bolt in. It will still require a little bit of modification to work perfectly with your turbo. What turbo are you using? I am using a 90 Degree VF8.
- Lurker-King
Exhaust Pics!
Major thanks to Nick for building such a great exhaust with limited time and equipment. Couldn't have asked for a better job. Thanks man
It is a 3" GPMoto Downpipe into a custom 3" cat-back into a Magnaflow. 3" Catless from the turbo back sounds great! Very deep!
I'm going without a tip for now. Looks very sleeper!
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
This new setup is just amazing! With the TurboXS MBC and Desnorkle/Semi- Coffee cup mod, you can really feel the car pull. We have had it set at 16 psi, and it is doing fine. I just ran it at the PIR Saturday night drags and I ran a 14.56 at 94 MPH at 12 psi.
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
14.56
The car pulls hard, but I didn't think that hard!!
Hell yah, great to hear you finally have the Leggy dialed in...
I fixed my car on Saturday too, no more CEL's, and its hitting 18 psi in the upper gears with plenty of fuel, and it pulls like a raped ape.
haha, glad you got it fixed! Yeah, my fastest was a 14.56 at 94 MPH, followed by a 14.61 at 95, and a 14.68 at 93. We dragged it 12 times on Saturday night! lol
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
Finally got around to typing up a mod list:
Interior
Blacked out Interior Panels
Blacked out Dash
CF Guage Pod
Autometer Boost Gauge
WRX Shift Knob
STi shifter boot
Exterior
Body Color Door Handles
Body Color Mirrors
Body Color Hoodscoop
Freshly painted wing
Blacked out Trim
Badgeless grill
Sylvania Silverstar Bulbs
Hella Supertones
Custom cleared rear turn signals
Pinstripes removed
4wd/ABS De-Badge
Blacked out Subaru Badge
Blacked out Legacy Badges
Sable Black Metallic WRX Wheels/ 205 55 16 Potenza's
Flat Black 94' Legacy Turbo Wheels/ Silverstone Rally Tires
Engine/Performance
EJ20G Swap
JDM VF8 Turbo
Forester Fuel Pump
04' Forester XT TMIC
Blitz Replica BOV
Fuel Cut Defender
TurboXS MBC
GPMoto 3" Stainless Catless Dp
Custom 3" Catback into Magnaflow Muffler
De-Snorkled
De-Resonated
CoilPack Conversion
Tranny/Drivetrain
JDM 3.90 5-speed Tranny
91' Legacy Turbo VLSD Rear Diff.
Excedy Stage 1 Clutch
WRX lightened flywheel
Forester Pedal Assembly
Forester Clutch Master cylinder
Suspension/Handling
WRX Struts
Espilar Lowering springs
Whiteline Flat Out STB
and a partridge in a pear tree......
Interior
Blacked out Dash
CF Guage Pod
WRX Shift Knob
STi shifter boot
Exterior
Body Color Mirrors
Blacked out Trim
Badgeless grill
Hella Supertones
Pinstripes removed
4wd/ABS De-Badge
Engine/Performance
EJ20G Swap
JDM VF8 Turbo
Forester Fuel Pump
Blitz Replica BOV
Fuel Cut Defender
TurboXS MBC
De-Snorkled
De-Resonated
CoilPack Conversion
Tranny/Drivetrain
Suspension/Handling
WRX Struts
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
The front has WRX struts with Espiler Lowering springs and the rear has 91' Wagon struts/springs. The wagon springs are rated for 600 lbs. more than sedan springs. That is why is looks lifted. It was kind of a last minute thing. The WRX struts/Tophats and Espiler Lowering springs rubbed on the inside of the wheel well, so we had to find a solution. I had 3 blown struts.
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
