Best Synthetic Oil to use?
livestrong14
I am getting ready to do an oil change on my 91' Legacy SS with an Ej20G swap. What synthetic oil should I use? What is the best 'bang for the buck'? Royal Purple? Mobil 1? WHAT?
-Devan
-Devan
91 SS -Carbon Bronze Pearl
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
91 Rio Red SS- RallyX Project
93 AWD Sedan- FOR SALE!
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
Best is yet to be proven. Get something you can find easily and you'll probably always be good.
I use Mobil 1.
I use Mobil 1.
Legacy Central
Yeah, Royal Purple's hard to find. I don't think you can go wrong with Mobil 1 even if it's a lousy corporation. I've never used anything less after driving my old GL several hundred miles at near redline with less than a quart when I got home and the car went on to run fine for a year before it when it went to the junk yard (tree fell on it).
Innovative Tuning
I used M1 full synth in my old WRX, and had noticable shearing after 2k miles. It felt great when new...so is prolly a good oil for 1.5k to 2k OCIs.
Although it is not within the rec. spec range in numbers, German Castrol is known to be a very thick 30 weight, and just an outstanding oil...I would consider this to be the best bang for the buck oil out there. It can be hard to find, though.
Whatever oil you pick, keep doing UOAs until you find the one that works (will take some time obviously). In the meantime...search here: http://theoildrop.server101.com/forums/ ... .php?Cat=0
- quasi-mod-o
Do you know what oil is in your engine now?
1993 Citroën XM Turbo C.T.
1993 Ford Spectron XL-T
1991 Fiat Croma 2.0T i.e.
BAC5.2
- quasi-mod-o
Then he should keep using the Motul IMO.
Changing oil brands = bad.
BAC5.2
It IS excellent. RBF600 is far superior to any fluid I've ever used. Even ATE SuperBlue!
I wasn't saying he was using Motul. I was answering the question about which is the best synthetic oil.
I believe the correct question, is, "is it safe with my rubber seals?"boro wrote:is it safe with ABS? I am looking for a harder fluid.BAC5.2 wrote:It IS excellent. RBF600 is far superior to any fluid I've ever used. Even ATE SuperBlue!
I also believe it is DOT 4 rated, so it *should* be safe with your seals and your abs....
DOT 5 will destroy normal seals in brake systems and should be avoided...
Danny
500cc Shifterkart, 125cc Shifterkart, 01 MX5, 93 Legacy Wagon (DIY Turbo)
This should really go in the brakes forum.....but the main issue you run into with the Motul brake fluid, besides cost is the fact is absorbs moisture much more quickly then some of the other fluids. So if you just want to stick brake fluic in and not worry about it, then this stuff may not be the stuff you want.
It also depends too on your climate. Humid/moist climates....you should really change your fluid more frequently.
