02WRX/06Legacy combo (same as LGT)
Asking $260 shipped
Only cheats and non-enthusiasts? Really? I have sold a number of sets of these as just the rotors and the brackets. Why have I done that? Because on the 2.5RS the calipers are IDENTICAL to the WRX calipers and the only part that is an UPGRADE is the size of the rotors, which requires the bigger brackets. My customers appreciate the fact that I don't cram a set of unneeded calipers down their throat just to jack the price of the sale and put more money in my pocket. With the brackets and rotors, you can install them without even having to bleed your brakes. WAY easier than hooking up the existing lines!!! Though I will add that if you want to use them on a first gen legacy like most people here drive, you will want the calipers as well since the brackets don't mate to the 90-94 Legacy calipers...HellBinder wrote:I dont want to sound like an ass, but have you ever taken your brakes apart?
There is no bracket between the caliper and the hub assembly.
The caliper, however, being easily dismantled into two sections, should not be sold seperatly.
Only cheats and non-enthusiasts sell them seperatly.
If you look at the picture, the caliper's i have are complete
All you need to do is buy pads and hookup your existing brake lines.
