Hey guys, haven’t been hangin around much lately, work, other projects, hobbies and such… life, you know the story.
Anyway, looking to finally (maybe) do some engine work on my ’91 SS, I’ve held off installing my EJ20G heads due the low compression issue with stock pistons. But last night my Subie buddy down the road offered up a great deal on a set of EJ2.5 DOHC heads, the compression numbers look good with the 49cc chamber, and assuming I can address the water passage, coolant/oil feed & return and cam gear issues I think it looks good.
I’m concerned with running the N/A cam profile in a turbo engine and not getting optimum performance, so two questions:
One, what stock (or aftermarket) turbo specific cams will fit in the 2.5 heads? Will the EJ20G cams work? WRX cams?
Second, does anybody have timing and lift specs on the EJ2.5 DOHC cams? EJ20G cams? WRX cams? Maybe I can run adjustable cam gears and split the duration a little and use the N/A cams?
Gary
Turbo cams in 2.5 DOHC heads?
All_talk
Matt Monson
- quasi-mod-o
http://forums.nasioc.com/forums/showthr ... light=cams
And read the sticky about Marks' earlier use of the Ej22T block against the DOHC Ej25 heads. In short, don't bother changing the cams.
I don't think its' included anywhere online, but at one point Mark installed v3 STi cams into his DOHC Ej25 heads. Those are the only ones that will fit( ie Ej20K cams). He hated what they did to his powerband. He did pick up 25 peak horsepower, but the car fell flat on it's face down low. It took more than 1000rpm more to make the power. He literally only ran them for 48 hours before he tore the engine apart and took them back out. Now he uses them in an NA engine that revs to 7500rpm and runs stock DOHC Ej25 cams in his stock heads...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Suby Hai!
