engine, wiring harness, and rear diff are gone. 4eat still there, worked find. most of the interior is also gone. anything else please ask and i'll let you know
The bearing's condition doesn't matter though, I picked up a new set for mine, but it wasn't only the bearing that was bad. I can seperate the hub myself if you'd rather not press it out, I've access to a press and the hub wouldn't make it too much bigger to ship.
Let me know what you'd take to ship it to zip 63532, Missouri...
thanks a bunch!
Legacy Rally Guy wrote:I'm in need of the right rear spindle...
thanks a bunch!
let me see if i can take it out, everything is pretty rusted in back
How's the suspension? Will it swap into my '94 L-wagon ? My rear end is completely shot as far as struts are concerned. A few elastic bands stretched from the bottom of the strut to the top of the strut would be a 'vast improvement'
Also, the wheels look half decent... although i believe those are also 15's -- would be an improvement over my stock Subaru hubcaps...
Lee M. Lemoine
'94 Legacy Alpine Wagon 5MT
'06 Legacy GT Limited (R.I.P.)
if you'd like to drive over i can give you all 4 shocks and struts for $50. your welcome to take a look at the wheels to while your down here
