I read on Laurals post and one other, but on the way to school today (40 degrees out) parked the car, and the brake light went on the dash. when i get out to the car, things i'll check before turning the key to go home are:
1) Brake fluid resevior. full? EMPTY for some reason???
2) Bulbs
3) pads (through rims)
i installed new coilovers during the summer and the car has only been driven about 3000 miles since then, and the brakes were bled then. i'm thinking i have low pads.... but not dangerously low?
just looking for other culprits. thanks!!
92 EJ22-T touring wagon
Luigi
Brake Light on Dash
NuclearBacon
NuclearBacon
to answer my own question, as quoted from the 92 FSM:
ahem...
"Under normal conditions, the float remains above the reed switch, and thr magnetic force from the permanent magnet in the float is unable to activate it. therefore, the circuit is kept open, and the warning light remains off. the float lowers as the brake fluid level lowers and if it falls below the specified fluid level [approx 30 mm (1.18in) below the MAX level line] the reed switch will be activated by the perminent magnet, closing the circuit. in this event, the warning light comes on and warns the driver of a reduction of the brake fluid level.
However, the lamp may be lighted momentarily even when the brake fluid surface is still above the specified level, if the vehicle body tilts of swings largely. "
ahem...
IronMonkeyL255
My brake light would come on when I am flogging it and using the brakes alot. I think the liner comes out of the lid and pushes the float down. Just taking off the cap will fix it for me.
Rio Red '91 Legacy SS
mattyg41383
something else to keep an eye on... if the "brake" light and "battery" light come on together, but intermittantly, could be alternator on its way out. (i had to deal with this about a month or so ago)
-Matt
1993 Legacy SS - auto
1997 Impreza coupe
1986 XT - 14.5s @ 95mph
1990 Legacy wagon "the Red Dragon" -sold (300K miles and it lives on)
1997 Impreza coupe
- quasi-mod-o
