Two "L" trim front seats in blue velour. Other than the tear on the driver's side there's nothing wrong with these, I simply replaced them with more supportive and adjustable seats.
Passenger's side front axle with complete wheel hub from an AWD. The wheel bearing is bad, but I replaced the whole assembly with one from a junkyard, so the axle is still perfectly good and usable, with CV boots still intact. The rotor could use resurfacing but as far as I know is also fine.
Top of stock N/A airbox with working MAF sensor. It's just a spare, I ended up with three of these for two cars. I'm almost certain the sensor is working anyway, if you need one you may as well try it, it's free.
I'm located in West Linn, OR (suburb of Portland). If you really want it I'm willing to ship the airbox (or take the sensor out and ship that). Other stuff is local only.
