The fitting seems snug enough, but is that really the best way to make the connection?
After getting the tubing zip tied down in the engine bay and routed up through the dash, I duct taped the pod to the steering wheel and took it for a spin. I haven't put teflon tape around the connections yet. After a quick drive around town, I saw the vacuum typically range from 10-20 hg. WOT up an on-ramp I saw 8-9 psi. I thought the stock boost was 7 psi -- does that mean this gauge is off by ~2 psi?
Lastly, seems that even slight deceleration in gear causes the boost to get dumped; is that right?
