EJ25 Need some advice
My buddy had a 2000 Outback with the 2.5 liter motor. It blew a head gasket (like most of them do, so I hear) and we are looking to swap in a new motor. We want to keep things as simple as possible. I see that there are a LOT of 1995 to 1999 ej25's out there, especially on egay. I can't seem to find an ej25 out of a 2000 though. Is the 95-99 ej25 significantly different than the 2000? Could I use the bottom end from a 1999 motor and bolt up all the accessories and wiring harness from the 2000? Or, should I just get a 2000 motor?
Sold :-( My 1991 Sport Sedan EJ22t 4EAT
WRX Seats, K&N Panel Filter, 3" Turbo Back Exhaust
Current Subi: 1998 Legacy GT Wagon 5sp in the midst of an EJ257 STi swap with 6sp. Woohoo!
Matt Monson
- quasi-mod-o
The problem with the '99 shortblock is 2 fold.
#1 If you use it, you need to use the phase I (thicker) head gasket. If you don' the pistons will hit.
#2 Even though the pistons protrude further from the top of the deck than the phase II engines, they also have a deeper cutout on the piston top. As such, they will drop your compression ratio, thereby robbing you of some power.
It will work, but you need to follow #1 and accept #2...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Suby Hai!
I found a few 2000-2001 motors. They're much harder to find and they're a bit more expensive. I guess it's because those motors have a tendency to burn through head gaskets so they're aren't as many left and the ones that are around are in high demand.
