Will STi injectors work?
THAWA
Post by THAWA »
oh right, version 6 sti injectors. As I said sometime within the last 6 years the pressure changed. I don't know when the pressure changed, and for which cars when it changed. It's possible that version 6 sti's were still using 36.3psi, and the change occured with the new generation for the imprezas. I know the legacy changed as early as 99 if not earlier.
I don't think 98's had a higher pressure, but whatever. I've said what I wanted to say. And like you said, it's still an easy fix.
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
ShaggyGT
Post by ShaggyGT »
Hmm... Ok so I need a new FPR. I can handle that. But I am not running JDM injectors, I am planning to run the USDM STi type yellow top injectors. The '05 Legacy GT turbo, Forester XT, Outback XT, and STi all run the same yellow top side feed injectors. They are "said" to be rated at 550cc. I can definitely see how a new fuel pressure regulator would be need for that much added flow. Thanks the good information.
-Matt
1991 Legacy Turbo Sedan
2005 Legacy GT Sedan (STi Conv.)
dzx
Post by dzx »
So does that mean you should be able to pick up a fpr from a newer subaru?
///M
'93 Legacy SS - part out
wrxsubaru
Post by wrxsubaru »
dzx wrote:So does that mean you should be able to pick up a fpr from a newer subaru?
Ive heard of a SVXer doing this with a I belive 2001 2.5rs FPR.
Quick question does anyknow if the injectors are the smae betweeen the NA legacy and the SVX, and if they are that would mean the 550 STi injectors would be bolt ins?
A Dodge Viper sticks to the road like a babies but does to its diper, shitty.
azn2nr
Post by azn2nr »
mostly all side feed injectors that are "upgrades" will fit in the na rails
-jason
IronMonkeyL255
Post by IronMonkeyL255 »
Oops. I only read the first page before posting. My question was already answered.
Rio Red '91 Legacy SS
gnuman
Post by gnuman »
What THAWA is saying is that the fuel flow is based on stock pressure for that particular injector. If the injector is from a year that uses higher stock pressure than yours, then the fuel flow will be less than rated (pattern may be bad as well), resulting in a net loss of fuel flow at the lower fuel pressure. The higher flowing injectors will not be as much of an increase as you might think, as well.
1992 Legacy L Wagon 'Emily" Ice Blue, plush seats, roof rack, towing hitch, upgraded radio/CD player, LS alloy wheels, and lots of love! 180K miles and going very strong!
You will get my Legacy from me when you pry my cold dead fingers from the wheel.
free5ty1e
Post by free5ty1e »
So once you go to 92-94 NA fuel rails, the world's your oyster as far as high-flow side-feed Subaru and Nissan injectors go... correct? Are there particular injectors that just won't work or do we just pretty much assume any of 'em will work with the NA rails?
And let's talk about spray pattern:
My assumptions - if the injectors are rated for a lower pressure and ran at a higher pressure, the spray pattern will most likely be intact and proper.
However, if the injectors are rated for a higher pressure than you run them at... the spray pattern may be defunct?
-Chris
91SS 4EAT stock, 200k mi
THAWA
Post by THAWA »
Well there's quite a few different side feed injectors. Obviously any style that is similar to the 90-91 NA AT and 91-94 turbo wont work. I think a few versions of STi's used this style. As well as some 300zx's and a few other nissans. I know denso makes a 550cc/min version of this style as I'm sitting on a set right now. There's a few other side feed styles, like what the supra uses.
An interesting thing to note here though, our NA injectors are supposed to flow 270cc/min right? Well if you look at Joshs flow testing on 92-94 NA injectors they do flow 270cc/min: http://bbs.legacycentral.org/viewtopic. ... 391#119391 at 43psi. Maybe we've been wrong about the static pressure being 36.3 psi? Or maybe we've been wrong about what the NA injectors flow? Anyone care to comment?
IronMonkeyL255
Also, what fuel pressure to the Nissans run at? They may run a higher pressure as well......
douglas vincent
Post by douglas vincent »
Who actually has a fuel pressure guage hooked up to their vehicles right now?
My static fuel pressure ranges from 36 to 43, usually at the 43 level though, climbing to 50 on boost.
ShaggyGT
Post by ShaggyGT »
IronMonkeyL255 wrote:Also, what fuel pressure to the Nissans run at? They may run a higher pressure as well......
The fuel pressure of the car does not matter. What does matter is the pressure the injectors are tested at to give said Injector CC's. Take a look at some of the injector flow charts people have posted from RC, you will see they list the pressure used.
-Matt
TheDaveler
Post by TheDaveler »
Anyone know what injectors fin in 91 Turbo rails? I have a 90 N/A that I could get the rails from as long as the turbo ones could go on, so both cars are still operational... if the 90 n/a ones have more modding potential. Anyone?
91 SS 5sp ~ 90 Wagon w/air susp ~ 92 Loyale 03 WRX - ap stage 2 ~ 08 Legacy 2.5i
kleinkid
EJ20G 440cc inj.
Post by kleinkid »
I have just installed the 440 cc grey top fuel injectors into the stock 1991 Legacy Sport Sedan EJ22T rails. I do have a set of 92-94 na rails and the EJ20G 440cc Subaru gray tops do not go in those rails. I obtained and compared a 90-91 na rail with the white(light gray) injectors installed, with my stock '91 EJ22t rails and they are the exact same. Inside the bowls, the dimensions, the lands and sealing areas are the same on both rails. The physical size of the injectors and the soft goods(o-rings, seals etc.) are the same.
TheDaveler
I was thinking of going with Nissan SR20 Injectors, anyone know what kind of flow id need for a 30psi boost monster? (cc)
douglas vincent
I am running about 1200 cc at 30 psi. Modded STI sidefeeds (820 now) with a rising rate fuel pressure regulator.
Innovative Tuning
Post by Innovative Tuning »
I've been running US STi injectors in my legacy SS using the 92-94 NA rails for a few months. Worked fine.
91RHDLEGACY
Post by 91RHDLEGACY »
92 legacy injectors fit in the 91 legacy, I have my right bank fed with 92 injectors, and my left being fed on the stock 91's, they look different, but fit perfect.
Reliable + Cheap = Not Fast
Cheap + Fast = Not Reliable
Fast + Reliable = Not Cheap
91 rhd legacy wagon n/a ej22 (runs great)(never ending tranny issues)
92 lhd " wagon n/a ej22 (parts for sale)
93 lhd " sedan n/a ej22 (dont run right)
91RHDLEGACY wrote:92 legacy injectors fit in the 91 legacy, I have my right bank fed with 92 injectors, and my left being fed on the stock 91's, they look different, but fit perfect.
Are they n/a or turbo injectors? If this is on a turbo legacy, then yeah, that's fine. If it's on a normally aspirated legacy, the injectors & rails are different and shouldn't work together.
Also, there are some differences in flow, which can lead to the engine running richer or leaner.
pisces_0
Post by pisces_0 »
THAWA wrote:An interesting thing to note here though, our NA injectors are supposed to flow 270cc/min right? Well if you look at Joshs flow testing on 92-94 NA injectors they do flow 270cc/min: http://bbs.legacycentral.org/viewtopic. ... 391#119391 at 43psi. Maybe we've been wrong about the static pressure being 36.3 psi? Or maybe we've been wrong about what the NA injectors flow? Anyone care to comment?
I've been trying to get to the bottom of this myself, and think I've finally found the answer to the static/base fuel pressure question.
Straight from the '92 Service Manual:
Pressure Regulator
By returning fuel so as to balance the above pressure difference and the spring force, the fuel pressure is kept at a constant level 250.1 kPa (2.55 kg/cm3, 36.3 PSI) against the intake manifold pressure
Also, the part number for the fuel pressure regulator is the same between the turbo and N/A fuel systems (#22670AA050). Looks like static/base fuel pressure is, indeed, 36.3 PSI.
91RHDLEGACY
the 92's fit in the 91, they are both n/a engines, not turbo. there are no leaks, no power increase or loss. the injectors just physically look different. you can come look at my car, and hear it run if you dont believe me.
MT or AT?
91RHDLEGACY
AT
93Leg-c
Post by 93Leg-c »
[quote="Legacy777Also, there are some differences in flow, which can lead to the engine running richer or leaner.[/quote]
Since cylinder #4 in my '93 NA and my '93 ss ran/runs very lean, does this mean that I can fit in an injector with a higher flow rate and possibly solve that lean-cylinder issue?
'94 TW
Arctic Assassian
Post by Arctic Assassian »
that is one damn good question. but first, have you had that injector tested or done some form of fuel system cleaner?
Kickin' it old-school.
