0 compression with dohc swap/ I think I have a bigger proble
Then what could it be even if you forgot a head gasket there would still be compression on 2 of 4 cylinders were as I have 0 on all 4. Next a missing intake manifold gaskes or exhaust manifold gasket would not cause this problem. So that would leave a stuck open valve or valves. I got the valve stem seals tested and they came back fine. Thats why timing is hard to over look as the problem. If I am missing something please let me know?
One of the crazy's boosting a NA!
14.3 @ 93mph
14.3 @ 93mph
Number 1 needs to be in the middle of the stroke, so that all pistons are in the middle of the stroke.
You don't time the dual-cam motors at Top Dead Center.
- quasi-mod-o
Stop taking these half assed pictures that are attempting to be right. Take me a picture of the complete front of the engine. Also, give me the part number that is stamped on the belt. I refuse to get down in the trenches with this pubescent arguing and mental masturbation, but will help you solve your problem if you give me decent information to work with. Garbage in gives you garbage out. I'll check back later and see if you are trying to help yourself...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Suby Hai!
The cams being torqued down too much wouldn't result in zero compression. It would result in a seized cam though.
Does the motor turn over easily by hand (it should be nearly effortless because it's not making any compression.
How did you test the compression tester?
- quasi-mod-o
Those pictures don't really tell me a whole lot. First thing I would do is get all the timing marks lined up properly and see if that is right or not. There's nothing clear in this thread about you actually doing this properly yet. I suspect that it's still a belt alignment issue. It's not a gear issue. The teeth count on the gears was the same from 89-98. That's not the issue.
Next thing I would do is take off the belt and pop closed the open valves. Then I would test compression on every single cylinder with the belt off and see what the results are. This will tell you if it's maybe valves or head gasket related before you reinstall the timing belt. After that, check back...
Suby Hai!
Suby Hai!
- quasi-mod-o
They are not. They changed with the change in design in tensioners in '99...Splinter wrote:I was under the impression that all EJ DOHC belts were the same?
Suby Hai!
Suby Hai!
Pictures to show the timing alignment.
I know for a fact that the belts are diffrent between a 96 dohc and a 99, and also know that the tensioners are diffrent. Next that would mean that do to the diffrent styles of tensioners that all who do the dohc swap using our block would need a pre 99 timing belt?
14.3 @ 93mph
14.3 @ 93mph
- quasi-mod-o
- quasi-mod-o
Well,
You only showed us pictures of the timing belt for one pair of gears. We can't see the other side, but they should all line up perfectly. With the DOHC heads, there are 3 marks per gear that need to line up. The one with the marks out of alignment is the one, though none of this really matters at this point. The belt is coming off and needs to be redone.
And just to be sure, check compression on all cylinders while you have the belt off. It could still be a HG issue since one side shows zero compression and we don't have the best pictures, but the side you showed appears to be correct and it is also the side that is showing zero compression.
You really aren't saving yourself any time of effort by leaving the belt on there any longer. If it's not the belt alignment, the heads have to come of the block regardless. So, step away from the keyboard and pick up a wrench...
Suby Hai!
Suby Hai!
Is there any chance that you could have switched the cams (intake for exhaust and vice versa?). Although I think this is only possible on the passenger side head....
^^ douglas vincent you taken the words right out my mouth thats what i did and it sounds like the same problem.
also take that dam aluminum pully out as well and use a stock one.
