AVC-R installed
Locked
Dave aka DLC/dackampf
AVC-R installed
Post by Dave aka DLC/dackampf »
I had the guys at Modern Garage install an Apexi AVC-R this evening
and i must say, i'm impressed.
The performance is what i expected. The boost is much more linear
and not as peaky as it was before. The display is very nice and let
me have 1-4 readouts simultaneously from 6 inputs.
It's a great tool and much more accurate than the VDO boost gauge and
HBC.
If anyone would like to purchase my HBC or VDO gauge for a reasonable
price, please let me know.
eGroups eLerts
http://click.egroups.com/1/9698/1/_/_/_/973912680/
penty
AVC-R installed
Post by penty »
VDO gauge ?
Does it work in psi ? do you have a pic ? what is the needle travel from 0-15 psi like in mm.
The reason is I brought a gauge and mine sucks, needle moves about 5 mm between no boost and full boost, it is measured in bar which means nothing to me.
oh yeah, are you in the UK :)
cheers
John
----- Original Message -----
From: Dave <mailto:legacycentral@yahoo.com> aka DLC/dackampf
To: BC-BFLegacyWorks@egroups.com
Sent: Saturday, November 11, 2000 3:17 AM
Subject: [BC-BFLegacyWorks] AVC-R installed
HBC.
eGroups eLerts
eGroups Sponsor
<http://click.egroups.com/1/9616/1/_/_/_/973939125/>
<http://adimg.egroups.com/img/9616/1/_/_ ... 468x60.gif>
AVC-R installed
It's a VDO 0-30 boost gauge and it works very well.
You can find pictures here:
http://www.xmission.com/~dac/centric/boost.htm
I'm in Utah, USA, so shipping it to the UK wouldn't be very cheap.
It's mounted in an Autometer gauge pod, black, and works really well.
--- In BC-BFLegacyWorks@egroups.com, "penty" <penty@n...> wrote:
> VDO gauge ?
> cheers
> John
> From: Dave aka DLC/dackampf
evening
linear
let
and
> HBC.
reasonable
eGroups eLerts
http://click.egroups.com/1/9698/1/_/_/_/973963311/
JohnnyG
AVC-R installed
Post by JohnnyG »
A safe maximum boost on a "stockish" EJ20 is about 12-15lb psi, so a gauge with about 1.5 to 2 bar of full scale deflection is sufficient.
It is less important whether the graduations are in psi or bar, and moreso that your boost span achieves reasonable full scale defection.
You should be getting about 1 bar peak boost... no?
John Gillon
Sent: Saturday, November 11, 2000 11:41 PM
Subject: Re: [BC-BFLegacyWorks] AVC-R installed
VDO gauge ?
cheers
John
HBC.
eGroups eLerts
eGroups Sponsor
<http://click.egroups.com/1/9666/1/_/_/_/973969282/>
<http://adimg.egroups.com/img/9666/1/_/_ ... 8x602E.gif>
penty
AVC-R installed
Post by penty »
Sorry is that in English or have I been abducted and taken to Planet Einstein ?
Sent: Saturday, November 11, 2000 6:58 PM
John Gillon
VDO gauge ?
cheers
John
From: Dave aka DLC/dackampf <mailto:legacycentral@yahoo.com>
HBC.
eGroups eLerts
eGroups Sponsor
<http://click.egroups.com/1/9642/1/_/_/_/973970324/>
<http://adimg.egroups.com/img/9642/1/_/_ ... 8x602F.gif>
JohnnyG
AVC-R installed
Post by JohnnyG »
Sorry,... let' see if I can simplify... hmm... educate... whatever!
(In bars. 1.0 kg/cm2 = 14.22 psi)
You should have about 0.8 to 1 bar boost which equals about 12-15 lb psi on your EJ20. Select a gauge where this is about the full extent of the needle travel.
Oh... and you need a about 0.8 to 1 bar vacuum if you want a combination vacuum / boost gauge.
Someting like this....
<http://www.greddy.com/media/images/prod ... twhite.jpg>
Sent: Sunday, November 12, 2000 8:21 AM
John Gillon
VDO gauge ?
cheers
John
HBC.
eGroups eLerts
eGroups Sponsor
<http://click.egroups.com/1/9628/1/_/_/_/973973270/>
<http://adimg.egroups.com/img/9628/1/_/_ ... 468x60.gif>
penty
AVC-R installed
Post by penty »
I like it, I like it alot, I order things all the time from the USA to the UK it's it's really quite cheap, I bet you if you chucked it in a little box with lots tissue paper and padding it wouldn't cost more then $10
Sent: Saturday, November 11, 2000 5:21 PM
Subject: [BC-BFLegacyWorks] Re: AVC-R installed
--- In BC-BFLegacyWorks@egroups.com, "penty" < penty@n...> wrote:
> VDO gauge ?
> cheers
> John
evening
linear
let
and
> HBC.
reasonable
eGroups eLerts
eGroups Sponsor
<http://click.egroups.com/1/9641/1/_/_/_/974062218/>
<http://adimg.egroups.com/img/9641/1/_/_ ... 8x602F.gif>
Locked
