Part needed...
shemoves
Part needed...
Post by shemoves »
I need the metal coolant line that runs from the bottom of the block into the heat exchanger above the oil filter. Rust has eaten a tiny hole in mine. This is for a '92 SS.
shemoves
Post by shemoves »
Still in need of this part...
Post by entirelyturbo »
The long one, goes over by the water pump?
Part number 21328AA011, $29.77 list.
1993 Citroën XM Turbo C.T.
1993 Ford Spectron XL-T
1991 Fiat Croma 2.0T i.e.
shemoves
Post by shemoves »
I think so. Sits above the header, or maybe that's the UP...I dunno...it's marked "Bad!"
Blackbart
Vendor
Vendor
Post by Blackbart »
That looks like it goes to the oil cooler(?)
This was only on the 91's.
shemoves
Post by shemoves »
It does go to the oil cooler. Don't know what to tell ya, I've got a '92, and it's on it.
Splinter
Post by Splinter »
The same pipe is used on newer cars with the oil cooler (e.g. Forester)
Might make it easier to find
shemoves
Post by shemoves »
same size and everything? I think all the newer turbo models have them
