440cc injectors
kleinkid
440cc injectors
Post by kleinkid »
Just thought I would share. This is where I bought my 440cc gray top injectors
http://cgi.ebay.com/ebaymotors/JDM-FUEL ... dZViewItem
These will fit right into your stock 1991 EJ22T rails. They come with all new soft goods with the exception of the following parts, 16696AA000 spacer- injector and 16608AA020 seal-fuel injector, those are $6.37 ea. and $5.22 ea. from www.subarugenuineparts.com You will need four of each.
ramathorn
Post by ramathorn »
i saw those. but, wouldnt it be easier to just use ej18 rails (almost free at a junk yard) and then upgrade to sti injectors?
greg donovan
Post by greg donovan »
are the rails on a 91 ej22t the same as the rails on my 94 SS?
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
NuclearBacon
Post by NuclearBacon »
greg donovan wrote:are the rails on a 91 ej22t the same as the rails on my 94 SS?
...they should be.
-Luigi-
....Yes like nintendo
1987 GL10 Sedan 3.700 LSD
1988 XT6 FT4WD 3.900 Diff Lock
1992 EJ22T Touring Wagon 5MT Swap 4.111
adema2626
Post by adema2626 »
EJ18 fuel rails FTW :)
93 Imp wag, 94 Imp wag WRX swap, 99 Imp Sedan WRX swap, 01 Imp Outback Sport, 05 Outback XT, 00 Outback, 98 Outback, 93 Leg touring, 93 Leg wag, 94 Leg wag lifted ej22t swap, 79 Brat 4x4 EA81 4spd d/r swap, 97 Crown Vic lifted
