stage 1 clutch?
86ruguy
stage 1 clutch?
Post by 86ruguy »
Does any one know if there is a Stage 1 clutch kit available for a 92 AWD N/A wagon? Hints or links would be appreciated.
92wagon (wife's)
92 sedan (sold)
91 ss no mods (sold)
88 GL Wagon (broken)
dzx
Post by dzx »
you could use a stage 1 exedy clutch for a turbo legacy I believe
///M
'93 Legacy SS - part out
douglas vincent
Post by douglas vincent »
But NOT the pressure plate! turbo and NA use different pressure plates...
I have a used Exedy (20k) I will let go for $25 shipped to you. Its in good shape.
86ruguy
Post by 86ruguy »
you have just the plate? or is that the entire clutch?
92wagon (wife's)
92 sedan (sold)
dzx
Post by dzx »
That is strange other than the pressure ratings on the pressure plate, i would have figured they would be the same. What is different about them?
///M
Splinter
Post by Splinter »
One is pull, one is push
If its a hydrolic clutch, you should be able to use a pressure plate from a 98 RS
86ruguy
Post by 86ruguy »
nah, it's cable.
92wagon (wife's)
92 sedan (sold)
