How much should it cost (in the US) to replace wheel bearings on a 91
legacy turbo? I have only talked with one shop so far and the price
was very disheartening. Not only that but he did not believe me that
my legacy was a turbo and when I insisted he told me it was
some "weirdo variant", probably not a shop I want to be dealing
with...Anyway, some help on the wheel bearing thing is much
appreciated.
Kevin
eGroups eLerts
http://click.egroups.com/1/9698/1/_/_/_/974781140/
Wheel Bearing Woes
Justin Brande
Wheel Bearing Woes
I have seen a price of $400 for both rear wheel bearings, including
labor. In regards to that shop, I personally would avoid it. I can
understand someone being surprised your car is a turbo, but to not
believe you and call it a weirdo variant, that's strange.
Justin
91
price
that
> appreciated.
> Kevin
eGroups eLerts
http://click.egroups.com/1/9698/1/_/_/_/974782370/
Justin
91
price
that
> appreciated.
> Kevin
eGroups eLerts
bobjr94
Wheel Bearing Woes
I did my own and all the bearings and seals were around 115$..and
like 50$ to have them pressed in/out one the parts were off the car..
so a shop should would charge you like 200-250$ for parts, and if
they have there own press about 10 minutes per wheel once there off
the car and maybe 25 minutes per front wheel, 20 back to take it off
and put it back on..
so around 2- 2 1/2 hours at the most..120-150$ labor...320-450$, just
guessing..the book may say 3 hours or more and that's what they will
charge, even if it takes 2 hours..
eGroups eLerts
http://click.egroups.com/1/9698/1/_/_/_/974804581/
eGroups eLerts
Gord
Wheel Bearing Woes
Hi
just put one in my 91 Legacy turbo. the bearing and seals cost $107(non Subie parts) and the $161 to have them installed. those prices are Canadian $ which run about $10US=$15Cdn. i live in Nova Scotia known for the salt on the roads and in the the air so for stuff like that i have a shop do it because it takes heat and special tools to take things apart. Rust is a right bugger.
The bad news was that the ABS sensor had to be removed to heat the spindle to get the old bearing off. the sensor didn't survive this, $300 more and i had a new sensor and installed it myself, turn out that the Subaru dealers budget for a new sensor everytime the change a wheel bearing, the new sensors have a plastic case thought and probably won't rust in.
anyway that my tail of woe.
Gord
----- Original Message -----
To: BC-BFLegacyWorks@egroups.com
Sent: Tuesday, November 21, 2000 12:32 AM
Subject: [BC-BFLegacyWorks] Wheel Bearing Woes
appreciated.
Kevin
eGroups Sponsor
<http://rd.yahoo.com/M=150967.1016644.27 ... =974808973?> click here
Gord
appreciated.
Kevin
eGroups Sponsor
Barrett, Sam
Wheel Bearing Woes
Where do you live? I know a great place in the Seattle area... www.smartservice4u.com
-Sambo
-----Original Message-----
Sent: Monday, November 20, 2000 8:32 PM
appreciated.
Kevin
eGroups Sponsor
<http://rd.yahoo.com/M=150967.1016644.27 ... =974822809?> click here
-Sambo
appreciated.
Kevin
eGroups Sponsor
jason grahn
Wheel Bearing Woes
ROFL!! WEIRDO VARIANT?? HAHAHAH!!!
Oh, and yeah, you probably shouldn't go to that guy. He'll probably tell you
that you have loose muffler bearings.
Jason
_____________________________________________________________________________________
Get more from the Web. FREE MSN Explorer download : http://explorer.msn.com
eGroups eLerts
http://click.egroups.com/1/9698/1/_/_/_/974857142/
Jason
eGroups eLerts
Josh Colombo
Wheel Bearing Woes
don't forget about the warp drive intercooler! hahah
Josh Colombo
jcc189@psu.edu <mailto:jcc189@psu.edu>
of beats and rhythm" - ME
Sent: Tuesday, November 21, 2000 12:26 PM
Subject: Re: [BC-BFLegacyWorks] Wheel Bearing Woes
you
Jason
_____________
eLerts
http://click.egroups.com/1/9699/1/_/_/_/974857448/
Josh Colombo
you
Jason
_____________
eLerts
Dave aka DLC/dackampf
Wheel Bearing Woes
And that blinker fluid that seems to leak like crazy on my Turbo.
--- In BC-BFLegacyWorks@egroups.com, "Josh Colombo" <jcc189@p...>
> Josh Colombo
> jcc189@p... <mailto:jcc189@p...>
> From: jason grahn [mailto:jgrahn555@h...]
tell
> you
> Jason
__
> _____________
eLerts
http://click.egroups.com/1/9699/1/_/_/_/974860724/
> Josh Colombo
tell
> you
> Jason
__
> _____________
eLerts
