wrx pedal box= 1991 legacy pedal box????
rallyboy_96
i want to know if i can put a pedal box from another subaru to my 1991 legacy ???
It should work providing it is:
A) of the same clutch release type (unless you are converting)
B) cable throttle (unless you are converting to throttle by wire-in which case I wish you good luck)
rallyboy_96
IronMonkeyL255
Would the throttle type even matter? The throttle pedal is on its own assembly separate from the clutch/brake assembly in cable-operated applications. Did they integrate the units for throttle-by-wire cars?555BCTurbo wrote:It should work providing it is:
Rio Red '91 Legacy SS
Same thing with hydro setups. I swapped to a SS hydro without toutching the throttle.IronMonkeyL255 wrote:The throttle pedal is on its own assembly separate from the clutch/brake assembly in cable-operated applications.555BCTurbo wrote:It should work providing it is:
That's a damn good point...
I don't know why on earth I thought that the throttle pedal was part of the cluster...especially because I did a 4eat > 5mt swap a few months ago...
