Tuning
gto7419
Tuning
Post by gto7419 »
Ok, so my car is running properly again... Almost....
Im running rich at the moment. Is it possible that the gas isnt burning completely because the timing needs to be retarded?
Im on limited tasking here because of a surgery I just had, so adding my programmable dis2 might take a week or two....
Is it possible this is whats causing my rich issues? Im going rich after every shift (I think this is because of the safcII settings). And, Im also going rich whenever I run into boost... Its running around 12s on the wideband when I start to run into boost.
I am dialing out as much signal as I can through the safcII and Im still running rich when boost comes in... Im pretty sure I dont have a boost leak, but I guess Im going to have to double check everything....
Setup =
ej22 n/a with t3 turbo
sti injectors
98 dohc heads/manifold
new plug wires
new spark plugs
safc II
06 wrx tmic + bpv
programmable dis2 awaiting installation
500cc Shifterkart, 125cc Shifterkart, 01 MX5, 93 Legacy Wagon (DIY Turbo)
