how to remove rear axle stub???
rallyboy_96
i need to rebuilt my rear diff on a 1991 legacy with the lsd.
but i can't figure out how to remove the rear axle stub. i know on some car they have a little bolt that hold it but i cant see it
somebodu can help me on that ???
IronMonkeyL255
From the diff?
The axle is held onto the diff with a roll pin. The diff has male stubs attached to it, and the axle is held onto the stub with the pin.
Rio Red '91 Legacy SS
rallyboy_96
Threshld1
Look inside the male stub, there is a star head/8pt bolt that connects it to one of the pinion gears. As to what size this is or where the heck your going to find a deepwell that will fit in there im still looking myself. Let me know if you find something
93 SS 5MT - TD05H-16G, 06 TMIC, Walbro, Zeitronix WB-02 - Scrapped too much rust
91 SS AT
97 Outback - Prodrive quick rack, DMS 40
91 SS AT
rallyboy_96
All I've seen are held in with a reverse torx head bolt. Are you sure it's not just covered in dirt and grease?
I've never been able to find the proper socket, but if it isn't too rusted a standard 1/4 drive 8mm will work if you pound it onto the head. An impact wrench is a BIG help here.
[size=75]-97 Legacy (ain't never gonna die)
-92 SVX (attention whore)
-86 Brat (more fun than the SVX)
-92 SVX Racer (lightest SVX)[/size]
rallyboy_96
IronMonkeyL255
Taking a quick look at my FSM, it looks like for the LSD, the stubs (spindles) are simply held in with circlips.
I looked, and yours is just like the one I took out of mine, and the hole is just a hole. Nothing in it. It mentions the spindle set bolt for non-LSD units......
rallyboy_96
rallyboy_96
So you just gripped the stubs somehow and pulled them out?
Did you put a rod or something through the spring pin holes to have something to hold onto?
Any special tools used, like a puller to remove the bearing races?
I need to get the axle stubs out without damaging them so I can remove the LSD from the diff housing.
rallyboy_96
