Could please someone explain, is a blow-off valve the same as a dump
valve, and the standard valve on Subarus is called bypass valve,
cause it doesn't "dump" the pressure????? If so, can it be changed to
a "dumping" valve?
I'm gettin' REALLY confused here...
MIguelito
eLerts
http://click.egroups.com/1/9699/1/_/_/_/975278839/
Blow-off valve/Dump valve/Bypass valve
Rod
Miguelito,
Check out www.mrtrally.com.au and browse around in the technical info
section. You will find an explanation on how blow off valves work plus much
more.
regards, Rod.
----- Original Message -----
To: <BC-BFLegacyWorks@egroups.com>
Sent: Monday, November 27, 2000 9:47 AM
Subject: [BC-BFLegacyWorks] Blow-off valve/Dump valve/Bypass valve
> a "dumping" valve?
> MIguelito
eLerts
http://click.egroups.com/1/9699/1/_/_/_/975286253/
more.
regards, Rod.
> a "dumping" valve?
> MIguelito
eLerts
Miguelito
Rod,
thanks for the link, now I'll try to forget about replacing this
valve! I have to say though, that it would have been nice to have had
the whoosh noice described on every site that sells these valves...
In conclusion, I'll quote MRT:
quote
"Think twice, there are many other upgrades that will give MUCH
better value for your $$"
unquote
cheers,
Miguelito
--- In BC-BFLegacyWorks@egroups.com, "Rod" <melrod@o...> wrote:
> Miguelito,
info
plus much
> more.
> regards, Rod.
> From: "Miguelito " <awdturbodude@y...>
dump
changed to
> > a "dumping" valve?
> > MIguelito
eLerts
http://click.egroups.com/1/9699/1/_/_/_/975329771/
quote
unquote
cheers,
Miguelito
> Miguelito,
info
plus much
> more.
> regards, Rod.
dump
changed to
> > a "dumping" valve?
> > MIguelito
eLerts
penty
Hi
I had a noisey whooshing blow of valve on my other car, it just bugged me in the end, about the only noise that does sound nice though is the zzzzbbb zzzeebb zibazib noise ( high pitched whizzing) that rally cars make when they are slowing for corners I think this is something else ?
Please help me out someone
cheers
¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø,¸¸,ø¤º°`°º¤ø¤º°`°º¤ø,¸¸,¤º°`°º¤ø,¸¸
Info: John Carlsson UK 92 Legacy 4 cam Turbo Estate
E-mail : penty@nettaxi.com
To: BC-BFLegacyWorks@egroups.com
Sent: Monday, November 27, 2000 12:56 PM
Subject: [BC-BFLegacyWorks] Re: Blow-off valve/Dump valve/Bypass valve
Rod,
quote
unquote
cheers,
Miguelito
--- In BC-BFLegacyWorks@egroups.com, "Rod" < melrod@o...> wrote:
> Miguelito,
info
plus much
> more.
> regards, Rod.
> From: "Miguelito " < awdturbodude@y...>
> To: < BC-BFLegacyWorks@egroups.com>
dump
changed to
> > a "dumping" valve?
> > MIguelito
eLerts
eGroups Sponsor
<http://rd.yahoo.com/M=150967.1016644.27 ... =975331911?> click here
cheers
Rod,
quote
unquote
cheers,
Miguelito
> Miguelito,
info
plus much
> more.
> regards, Rod.
dump
changed to
> > a "dumping" valve?
> > MIguelito
eLerts
eGroups Sponsor
Rod
no problem.
i came to that conclusion also.
ps. the mrt site is one of the best. i have had work done by them. very
proffesional and they DO know what they are doing. they have been rallying
cars for years and now are driving a wrx.
nothing beats experience.
rod
Sent: Monday, November 27, 2000 11:56 PM
> Rod,
> quote
> unquote
> cheers,
> Miguelito
> > Miguelito,
> info
> plus much
> > more.
> > regards, Rod.
> dump
> changed to
> > > a "dumping" valve?
> > > MIguelito
eGroups eLerts
http://click.egroups.com/1/9698/1/_/_/_/975362086/
rod
> Rod,
> quote
> unquote
> cheers,
> Miguelito
> > Miguelito,
> info
> plus much
> > more.
> > regards, Rod.
> dump
> changed to
> > > a "dumping" valve?
> > > MIguelito
eGroups eLerts
JohnnyG
Yes
Sent: Monday, November 27, 2000 11:47 AM
> a "dumping" valve?
> MIguelito
eGroups eLerts
http://click.egroups.com/1/9698/1/_/_/_/975379707/
> a "dumping" valve?
> MIguelito
eGroups eLerts
