Who all has bent a rod?
douglas vincent
Post by douglas vincent »
Tore down my 2.5 hybrid.
#4 rod is bent. Finally some damage other than a ringland! :)
Its not bent horribly, but enough that when the piston is installed you can tell something is funky because the piston is tight against the rear, and totally loose against the front.
When I pulled the motor apart tonight, you can barely see the rod is bent, but it just enough that you look at it and say, "something is funky here....."
Leave it to Mr. Vincent to bend a rod.
92ss satinsvoice
Post by 92ss satinsvoice »
a forged one at that.
Andy
94 L n/a 5spd, Rip
91 ss champagne - Rip
88 Leon GL Hatchback - DD
