04 WRX springs FS
04 WRX springs FS
Post by entirelyturbo »
Not mine, a friend has 04 WRX stock springs with less than 5k miles. Looking to get $50 for them, shipping extra of course.
These will fit 90-91 Legacies, and make a VERY nice suspension upgrade without being rock-hard, too low, or too expensive. I've been using 04 WRX springs for 15k miles and am still as satisfied as the day I installed them.
Thanks.
*Formerly DerFahrer*
dropdfocus
Post by dropdfocus »
I thought they fit the '92-'94 models if you swapped the front top hats left to right (just a haif off camber when installed)?
Jason
The fronts aren't the problem. It's the rears. You'd have to get 90-91 rear strut mounts to make them fit a 92-94.
Oh, and bump. Still for sale.
Red91SSFWD
Post by Red91SSFWD »
but do they lower it a little bit? i wanna be lower. . or should i go for wrx lowering springs
dropdfocus
WRX springs will lower the car a bit. You end up with little stiffer ride (nothing severe), but you'll also end up with a better handling car too.
Jason
Red91SSFWD
well i get paid tomorrow. . so i think im gonna buy them tomorrow. . you said 50 + shipping? it'll be like about 100 maybe? do our cars come equipped with a stock camber kit, or is it like civics where im gonna need one to adjust the camber angle? I have a guy at my work that will do my alignment for free seeing as how i work in the service department at honda.. but id like to know so i can get that kit before i do the alignment.
Legacy Rally Guy
Post by Legacy Rally Guy »
Hmm, I picked up some 02' wrx struts and springs a while back, but they didn't fit my top hats and were too large for my rears... *tires would have bound against them.* I have a 91 SS, but it was a no-go.. My rear springs taper a lot toward the top hat... Do I have an oddball car? If so, I'm going to list the springs on here soon too.
Red91SSFWD
ya thats the springs AND struts. . the struts dont bolt right up, and you have to change the tops. the springs are supposed to go right on. . supposedly ha.
Legacy Rally Guy
Red91SSFWD wrote:ya thats the springs AND struts. . the struts dont bolt right up, and you have to change the tops. the springs are supposed to go right on. . supposedly ha.
I'm sure the struts would bolt in to appropriate tops, but my problem was the rims looking like they would hit the spring... Hmm, what tops would you advise? I know the fronts will fit no prob with a top change, so maybe I'll just use the stock springs in back and try the wrx springs up front.. hehe I'm thinking this may promote understeer though.. :P
Red91SSFWD
well are the 02 wrx springs any different from the 04? I was told by my friend that the 04 wrx springs would fit right onto the stock 91 ss struts. . Really, im not sure if the 02 is different. But since you wanna do the wrx struts on your vehicle too, i think the front struts and springs bolt right up. . I'm honestly not sure what tops you would need in the rear, but i could research that for you.
Yes, Red, the 02-03 WRX rear springs are different from the 04+.
I replied to your PM, btw.
