my front mount journey
Front, Top, Air, Water.
92ss satinsvoice
Post by 92ss satinsvoice »
ok every one i jumped in with both feet and dont give a damn! i didnt sleep before i went to work, so when i got off at 12:30 afternoon. i started tearing my car apart.
here we go.
first i got the lights out and side lights with grill.
then i took the front skin off with the fenders attached. it made it really easy to take off.
another view.
beam is off.
you can see the saw i used a little and figured it cant do the job. so i went to ralli-tek to talk with my buddy for help. ill post more pics tomaorw as the story unfolds.
im dead tired, ive been up for two days. now im hittin the clubs with some friends to keep my mined off other crap in my life. 8)
Andy
94 L n/a 5spd, Rip
91 ss champagne - Rip
88 Leon GL Hatchback - DD
Whatever you cut, I recommend getting some zinc galvanizing spray from an electrician suppy place and coating the exposed metal. You can paint over it after if necessary, but the zinc will give you about as much weather resistance as the uncut metal had where it would otherwise get under any paint rather quickly. Grind away the old paint a little way around the new cuts before zinc-ing it so it's a smooth transition.
Good idea removing the bumper and fenders as a piece.
92ss satinsvoice
one of the fellers accidentally cut off the top bar so we had to weld it back on, then we cut off the bottom and it still needed more cut off. so the next day i brought my intercooler with me and cut it for the threrd time. then we went to a hard wear store and bought some bolts to mount it on the beam. drilled holes in the bar and it fit really nice.
here is the re welded top beam.
heres it done at the shop
bolted up nicely :D
and here is the final product.
all done in about 8-9 hours. now all ive got left to do is the piping and ill be done :-D
ill take a pic of it in the morning went its light out.
Andy
94 L n/a 5spd, Rip
boro
Post by boro »
where do you plan on running your pipes? through the fenders? you have ABS correct?
92ss satinsvoice
yes i have ABS. like all turbo models. im going to run the pipes off the turbo through the hole where the snorkel box should be. then im runing the rest eather under the front cross member or though the other fender where the battery is.
Andy
94 L n/a 5spd, Rip
Adam West
Post by Adam West »
What brand IC is that?
92ss satinsvoice
ive got no idea. my friend bought it from rev motor sports for $380.00. so im guessing its good quality. got some more things for my car.
avo fuel cut defender and a perfect power. picking up another tappered cuppler today and some t-bolt clamps. rest of the pipes will be welded together.
Andy
94 L n/a 5spd, Rip
92ss satinsvoice
lookin like this up coming monday im getting my perfect power and avo fuel cut defender installed. hopfully ill get my pipes all ready to be welded soon. then it will be time for a few road pulls for tuning 8) .
update: the project is moving along but its very expensive to do this type of set up. and if some one tells you its not. they dont know what there talkin about. it would be safe to say it would cost about $800-$900 or more to have this done. espesually if you dont have any connections or the equipment.
ive got about $300 more worth of stuff to buy now just to finish my project.
this is just freakin insane.
im going to bash my head into the wall for not thinking this all through. :evil:
Andy
94 L n/a 5spd, Rip
Post by 555BCTurbo »
I hope you have a wideband O2 for tuning your Perfect Power...because you cannot adequately tune it otherwise
92ss satinsvoice
i dont have one yet personly but we're going to barrow one.
Andy
94 L n/a 5spd, Rip
IronMonkeyL255
Post by IronMonkeyL255 »
What size is that core?
You still have a/c, correct?
Looks nice. That's almost exactly what I was planning on my '91, though when I tried to remove my bumper cover to scout out the fitment, I broke all the bolts I tried to remove......
Rio Red '91 Legacy SS
92ss satinsvoice
i be leave its. 8.5" tall. 28" chamber to chamber. 2.5" core.
shes almost done.
Andy
94 L n/a 5spd, Rip
gto7419
Post by gto7419 »
very nice!!!
500cc Shifterkart, 125cc Shifterkart, 01 MX5, 93 Legacy Wagon (DIY Turbo)
92ss satinsvoice
thanks, not a bad job for my first time doing such a mod.
i have my perfect power installed and the fuel cut defender. but i think we got the two wires back words on the defender cause im still hiting fuel cut :? .
oh for the love of acceleration 8) .
Andy
94 L n/a 5spd, Rip
QuickDrive
Lurker-King
Post by QuickDrive »
Did you change anything else? Turbo? MBC?
Or did you just add the big motha FMIC?
R I P-------- 91 Turbo 4EAT --------R I P
92ss satinsvoice
well i installed my boost controller like a month ago. im still running the stock turbo till i can afford a vf30 or a tdo5.
when my front mounts done, the exhaust is next.
Andy
94 L n/a 5spd, Rip
BXSS
Post by BXSS »
I see tubing in the fog light holes, is the FMIC finished?
This took me & my buddy 1.25 days to complete, fitting the I/C (31"x12"x3") into the beam & b-cover was a pain in the butt.
Looks good .
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
92ss satinsvoice
ya there 90 degree into another 90 degree then up through the engine bay. no its not finished but im almost half way done with them though.
i just ordered new front seals, cams and main. also a timing belt all to gether for 59.00. :-D
Andy
94 L n/a 5spd, Rip
dropdfocus
Post by dropdfocus »
Very nice!! A lot more stealth than mine sticking way out there for everyone to see...
Jason
92ss satinsvoice
im thinking on cuting the little beam on the bumper skin like yours. but i dunno. this weekend i installed new front seals and timing belt. man that was a pain in the ass. im really tired.
Andy
94 L n/a 5spd, Rip
92ss satinsvoice
update: so far these passed days i dont have anymore oil leaks. no more giant burning oil clouds billowing out from my car. YAY!
NOW i finally believe i will have time to finish cutting my pipes this weekend. i reseved my t-bolt clamps, and 2 more cupplers. 5 ply buddy, that shit its thick!
now all ive got to buy now is a 3"/2.5" reducer cuppler, a 1.75" 90 degree silicone cuppler and the HKS BOV!!!
patients is a verture :-D
Andy
94 L n/a 5spd, Rip
92ss satinsvoice
this last weekend i was able to finish cutting the pipes as i wanted. mission accomplished. ive got a few pics for yall.
both sides are going to go under the frame notches for the wiring harnes. looks really cool.
there all cut and ready
i should of toke a pic when all the pipes where on the car.
Andy
94 L n/a 5spd, Rip
smh0101
Post by smh0101 »
How did you remove the bumper so easily.
nexgt week I am installing JDM fogs so I need to know.
92ss satinsvoice
it qiute simple. first you remove the grill, then the corner lights and head lights. you will see plasic type rivites with screws in them. take them out. there will be about 6 more under the car for the bumper skin. there a bitch to get out. next there are two 10mm bolts that hold the skin to the fender. there right in front of the wheel. then there are another two 10mm nuts that are in the fenderright where the corner light goes.you will need an extention and maybe a deep socket.
Andy
94 L n/a 5spd, Rip
92ss satinsvoice
heres the pipes all tack welded and in there homes.
Andy
94 L n/a 5spd, Rip
