Hey i have a few questions for you subaru experts. I have a 93
touring wagon. I was wonderin when you turn the key to the on
position(click before u turn the ignition) are you supposed to hear
anything such as the fuel filter or any noise at all? Also how do u
do it to read error codes. For some reason my idle sometime flutters
lightly. i was just wonderin maybe there is sometin i have to do or
replace. the car has almost 97k. Any info is greatly appreciated
eLerts
http://click.egroups.com/1/9699/0/_/_/_/976752205/
A few Questions
Josh Colombo
A few Questions
I don't hear anything on my 90 legacy, It's not like some of the cars you hear.
As far as the codes go....check out my webpage, under the Notes & Tips section, there is info on how to pull the codes and what they are. If you have any questions drop me a line. Here's my page www.personal.psu.edu/jcc189/subaru/subaru.html
Josh Colombo
jcc189@psu.edu < mailto:jcc189@psu.edu>
of beats and rhythm" - ME
-----Original Message-----
From: SpraCrx91@aol.com [ mailto:SpraCrx91@aol.com]
Sent: Wednesday, December 13, 2000 73 PM
To: BC-BFLegacyWorks@egroups.com
Subject: [BC-BFLegacyWorks] A few Questions
eLerts
eGroups Sponsor
<http://rd.yahoo.com/M=102308.1038796.27 ... .yahoo.com> Click Here!
Josh Colombo
eLerts
eGroups Sponsor
Carl Andersen
A few Questions
In my 93 Touring Wagon you can not hear the fuel pump at startup time. I just replaced it and even with no fuel in the filter there was no sound from the pump when the ignition was turned.
Matt Scicchitano
A few Questions
> anything such as the fuel filter or any noise at all? For some
> lightly.
It's not uncommon to hear the ABS unit go through it's cylce when you
turn the key( a slight humming noise that only lasts a second or two).
As far as the idle, it could be half a million things. The Idle Air
Control Valve controls the idle and they are known to get dirty
and/or go bad. Usually results in a fluctuating idle, and usually
gets better the longer the car idles. Other things could be the O2
sensor, ever-so-slight vacumn leaks, state of tune, etc. And other
times it could simply go away with doing an ECU reset. Good luck.
-Matt
eLerts
http://click.egroups.com/1/9699/0/_/_/_/976766785/
> lightly.
-Matt
eLerts
