How interchangeable are the ej engines?
Arctic Assassian
I know that any motor will bolt into pretty much anything, But what about just shortblocks? I've got a 91 SS with a #1 rod bearing that is about to go. I'm moving to oregon in october, and I'm not sure if I want to put in an N/A motor, till I get there, or if I can swap in say, just the shortblock from an STI, but keep my heads and stock ECU? What, if any shortblocks will fit the heads properly? Gaskets? T-Belt? I hate my life....
Kickin' it old-school.
douglas vincent
An STI short block will work fine, but you will have to get a stI timing belt tensioner....I think....
Matt Monson
- quasi-mod-o
Doesn't matter. Guys have been mating 2.0l heads to those blocks since the day they were released. And I know a couple of local guys who have mated them to Ej22 heads. There's really no issue there.boro wrote:what year STi? Wont the pistons overlap the combustion dome on the head slightly?
It's going the other way that makes issues. In particular SOHC EJ25 heads cannot be bolted to EJ20 blocks because the bore is so much smaller that the head gasket won't seal.
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Suby Hai!
Arctic Assassian
so matt, Youre saying that I could essentially grab the service manual for my 91 turbo, and follow that without fail, for shortblock replacement. Has anyone done this? Will my stock EM be able to handle it? I need a new shortblock, and I want to do this as painless as possible, but I cannot find a stock 2.2t block up here in alaska.
Arctic Assassian
If you are running it in stock trim (i.e. no boost increase, etc) I don't believe you would really see a problem based on displacement...
And then if you were to tune it, just keep an eye on things with a wideband
- quasi-mod-o
Most of the stuff that makes the engine "run" is attached to the heads or intake manifold.
If you keep your original heads and intake manifold, then yeah, the 257 shortblock should swap right in for the most part.
I believe the original knock sensor should work, and I believe the crank angle sensors swap too. Then I believe the coolant crossover pipe should change over as well, so you can use your same coolant temp sensors. Other than that, I believe everything will be the same.
Matt Monson
- quasi-mod-o
If he buys just a shortblock, it shouldn't come with that wheel. As stated above he will want to use ALL the parts from his Ej22T other than the shorblock (which by definition is only the case, pistons, cylinders and things like rings and bearings).
The only compatibility issue is that the Ej257 block has an additional case breather that will hit the early style coolant crossover pipe. The solution most guys use it to either cut it up with a cutting wheel and stick a rubber corks in it OR crimp the end of it after putting some silicon sealant in there and knock it over with a mallet. One is prettier than the other, but they both serve the same purpose...
Suby Hai!
Suby Hai!
Arctic Assassian
