These came off of an early EJ20G from a Liberty/Legacy. They were on a car and running it properly before they came into my posession. I have peeled back the rubbers on them all and none of the tips are cracked. $100 shipped anywhere in the lower 48. Canadia add $10 more.
Note: There is a difference between early and later ones. If you are using WRX EJ20G heads, you will need to do a little grinding on the brass guide on the coils to make them fit your heads. It's not a big deal as long as you have a hacksaw and a dremel...
FS: 4 uncracked known good LGT ignition coils...
Matt Monson
- quasi-mod-o
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
Suby Hai!
Matt Monson
- quasi-mod-o
I think they are the same as the coils that went on that engine but I can't be 100% sure. I don't know if the change took place in '92 or not and also don't recall if that RS-RA was a '91 or a '92...
Suby Hai!
Suby Hai!
