Bad rear diff???
waldo320
Bad rear diff???
Post by waldo320 »
Well I am working on a 96l wagon. Every time I turn the car there is a horible vibration in the rear end so I put the fuse in for 2wd and no more vibration. Which tells me its in the back end some where so I have a used rear diff sitting in the garage. I empty the fluid today expecting to see metal shaving and chunks of stuff. All I see are some small particals of rust the megnetic plug has some chunks that look like rust to me? Is my rear diff bad?
One of the crazy's boosting a NA!
14.3 @ 93mph
Soul Shinobi
Post by Soul Shinobi »
Do you just mean metal shavings or truly rusty brown shavings? I would think that if there was low enough fluid that rust could develop that the thing's gone. Was it any better after filling it back up with fluid?
-Nick
1992 BC Legacy L Sedan AWD 5MT 272,000 - Wish you the best
1998 BK Legacy L Wagon 5MT 234,000 miles - RIP
2002 SF Forester S Wagon 5MT 215,000 miles - Current winter sleigh
1986 FC Mazda RX-7 GXL Coupe 5MT 155,000 miles - Summer cruiser
n2x4
Post by n2x4 »
Auto or Manual? Could be Torque Bind.
SUBARUEHS Racing
Soul Shinobi
I think only the the automatics have the 2WD fuse (correct me if I'm wrong).
-Nick
n2x4
Post by n2x4 »
Soul Shinobi wrote:I think only the the automatics have the 2WD fuse (correct me if I'm wrong).
You're right, I didn't connect that in the head :D . So yah, I stick with my guess.
SUBARUEHS Racing
waldo320
Post by waldo320 »
Yah no metal shaving or shiny anything in the oil pan just what looks like chunks of rust. Some really small some not so small. Yes its an auto. It only does it when I turn not when I go in a straight line. I put some new fluid in today well se what happens when I get a braking issue resolved. Posibles areas to look at for torque bind?
14.3 @ 93mph
Bheinen74
Post by Bheinen74 »
my advice is you need to rebuild the rear output of the tranny, ie, the clutchpacks for the rear diff output.
91 Legacy Sport Sedan 4eat
91crx si 165k
91crx Si 40.5k
85 BRAT Gl 140
97 SVX 74k
waldo320
Post by waldo320 »
Is there any write ups on how I do that sounds hard. Also Is it something in just the transfer case or the actuall tranny?
14.3 @ 93mph
Bheinen74 wrote:my advice is you need to rebuild the rear output of the tranny, ie, the clutchpacks for the rear diff output.
Ditto...your problem is with the rear extension housing clutch packs, not the rear diff.
waldo320
Post by waldo320 »
Yah drove it this after noon the fluid change made no diffrence. When I turn it sounds like something is pulseing in the back one sec it will grab the next second it does not? Still think it is the rear extension housing clutch packs?
14.3 @ 93mph
waldo320
Post by waldo320 »
So I know its not duty cylinode c right casue it will go into 2wd with the fuse. Which leaves to the rear extension housing clutch packs. What is the dip stick on the right passinger side of the car for oposite of the tranny dipstick? I took it out and the oil looks low it smells and feels like gear oil?
14.3 @ 93mph
That dipstick is for the front differential gear oil.
