Need Help...came here, figured I'd ask the experienced
I have a 1990 Legacy. It will run and rev (slight hesitations) in park, but when I put it in gear (auto-non turbo) it wants to die or just run super sluggish. Can't even climb the mound in my driveway. Changed the fuel filter, plugs, PCV, air filter, all to no avail (but they needed it anyways). checked the resistance at the coils and they're all pretty close. little over on the primary, but close. started to run sluggish about a week ago, now can't drive it at all. Haynes manual isn't helping, but I'm sure someone on here could.
Should I look at the MAF and if so, any way to check without spending the $250 to replace?
Manarius
Find someone with a known good one for sale and test it. Don't go buy a new one.
have you ever just let it sit in for a while before you give it gas or move?
mine can do that on cold starts, if it put it in gear and just let it set for a little bit and then slow start backing out giving it a little more gas it wont do it anymore
does it also idle low?
1990 Legacy LS, 4EAT
well ill see if it changes anything when i change my IAC valve tomorrow, but im not sure it will be exactly related to the problem your having
im defiantly not the most experienced person on the board so id listen to some of the others first
if you found a low mileage Leggy in a junkyard with a MAF for around $10 it couldnt hurt to change it and see if it helps
my TPS and IAC were $5.00 out of a junkyard ($300+ brand new)
Does your exhaust smell like gas?
How old are your plug wires and plugs?
How does the car run with the maf unplugged?
Im having a very similar problem with my modded car, and the car recently stopped catching on startup. I have a strong odor of gas from the exhaust and I have a feeling my plugs are all fouled....
Are you running catted?
500cc Shifterkart, 125cc Shifterkart, 01 MX5, 93 Legacy Wagon (DIY Turbo)
Could be plug wires. I went through a set a year until I got Magnecors.
Sounds a lot like wires. I've had the car run on 2 cylinders, making me think that something catstrophic had gone wrong.
- quasi-mod-o
