Once more about boost control
Miki
Hi everybody!
I'm sorry for once again bothering you with boost control, but I just
don't get it...
OK, I have the problem with too much boost on my car (occasionly even
20-21psi, as you probably have read), and I'm now considering
installing a manual boost controller (e.g. the HBC) to prevent my
engine from exploding.
Now, the question is, can the HBC be of any help in this?
Can the boost be set to a max figure with the HBC?
If I get it installed and set correctly, is the boost then always
kept below a certain max figure?
How the heck do these gadgets work???
I have a "bleed valve" thing on my map sensor (you know this), would
that still be necessary with the HBC?
Soooooo many questions and so little knowledge.. from my part that
is... does anyone understand what I'm trying to say here? I've read
about the HBC on their own website, and also on Dave's (thanks Dave
and Matt for the installation tips!), but...
HELP,
Miki
don't get it...
HELP,
Miki
Ben Lam
Miki, could you take some pic to show us hows your "bleed valve" set-
up? and where is it located?
I now using Apex-i AVC-R for my boost control and I just set in 2
different setting, one is higher boost and one is lower boost. In the
higher boost setting, I just set around 12psi but still not steady.
but in lower boost setting, it runs fine.
Dave. how do you set the Duty cycle %??
I took my car for emission test today, the mechanic told me the car
run rich @idle and I was in + 6% at 1st gear, will it be the problem?
Thanks for any suggestion!
JohnnyG
To: <BC-BFLegacyWorks@egroups.com>
Sent: Thursday, January 11, 2001 8:14 PM
Subject: [BC-BFLegacyWorks] Once more about boost control
> Hi everybody!
> don't get it...
No worries, and good to hear from you!... and it sound's like you are pretty
much on to it as far as your boost control. Depending on how far you want to
with raisng the engine performance, you are reaching a point where you may
want to take alternative paths.
Yes, I knew you would have problems, and it sounds like you had some boost
creep. I think driving in your colder climate would have prevented your
engine not exploding earlier!
A boost controller can come in many forms, both pneumatic and electronic
controlled, and this function can also be included in the ECU.
I don't know the HBC... yet
Working back from the turbo wastegate... we need to open this to either not
overspeed the turbo or control the intake pressure. The wastegate actuator
is controlled by an electronically controlled vacuum switching solenoid...
the factory setup is for the ECU to "pulse" the solenoid with a pulse width
modulated (PWM) signal providing proportional control of the wastegate
actuator. The control progam employs feedback from the MAP sensor and
others. The proportional conrol and range parameters are set within the
firmware of the ECU according to the factory.
The disadvantage of PWM control, is that the wastegate is opened earlier but
only slightly so the waste flow is narrow, and as revs increase the
wastegate opens more often and wider. Although wastegates all tend to leak
slightly anyway, this setup uses a control / feedback loop that can have a
fluttering and creep effect on the engine / turbo dynamics.
The alternatives are to control the wastegate differently, which can be
achieved by...
1 - pneumatic bleed / restrictor / accumator valves
2 - piggy back sensor conditioners (engine cut/fuel defend from
overboost/overspeed/over-rev etc).and replacement ROMs / piggy-back ECU
(boost controllers)
3 - complete replacement ECU
Boost controllers design varies and can incorporate various elements of the
control actuators and feedback loop sensor conditioning, but they usually
maintain closure of the wastegate at an earlier or controllable point of the
engine rev range, and open quickly at the preset boost pressure.
The objective with this setup is to build maximum boost as early as possible
in the rev range, however the engine dynamics become more "snappy".
The disadvantage with this approach, whether it be 1 or 2 above, is that
they are a piggy-back approach to "altering" the ECU firmware or factory
progam. In the quest for more power, this system of piggy-back workarounds
can become a bit of nightmare... unless you have a clear idea of your engine
performance goals.
As performance goals increase, you will need control of engine cut / fuel
defend, a modified engine map, etc... and a replacement ECU may end being
the better path.
Hmmm... normally the bleed valve (a piggy-back!) is in the vacuum solenoid
to waste gate actuator, and not the MAP sensor.
The objective of this setup is to delay the action of wastegate opening, and
it is usually one of the earlier modifications performed... after say,
exhaust and intake.
Whilst a simple bleed valve works, there are arguably better combinations of
valves or accumulators
The MAP sensor "sees" boost and vaccum and the usual workaround for a MAP
sensor is to add an electronic piggy-back signal conditining device to
change the sensor's analog output span.
The objective is to modify the output curve effect of the ECU map.
The disadvantage is at some point with high boost gains the MAP sensor
"flat-lines" it output as it is actually at full pressure (internal
mechanical span as it is only a silicon strain bridge mounted on a
diaphragm), and the piggy-back has provided semi-controlled modification of
the factory progam pertaining to control of wastegate actuation, but the
consequent impact to the ECU map / engine cut is haphazard.
A bleed valve on the MAP sensor will achieve the same sort of result but
more crudely.
Very high boost setups would probably use a replacement ECU with a
replacement MAP sensor of the appropriate pressure rating.
So Miki... that was an introduction to control / feedback loops, and an idea
of the issues in maintaining balance and control in the quest for more
power. Don't get me wrong, any of the above approaches is perfectly valid,
depending on your end goal.
In my experience with other people's EJ20 high performance modifications,
the factory ECU gets ditched fairly early, otherwise all the piggy-backs
become a pain to manage... but it all depends on how much power and
reliability you want. ... In your case, with your EJ20... I think that you
may be heading into 250-300hp territory where a replacement ECU is arguably
the better path... at some point you need to take control of the ECU map, as
fuel control and lean-out becomes an issue. Whilst the EJ20 doesn't seem to
be sensitive with the ignition timing running a bit too far retarded, a
lean-out condition at high boost / revs is very, very damaging.
My 2 cents...
John Gillon
www.clubsub.org.nz
> Hi everybody!
> don't get it...
achieved by...
(boost controllers)
performance goals.
the better path.
exhaust and intake.
more crudely.
My 2 cents...
John Gillon
www.clubsub.org.nz
Miki
Thank you John, I knew I could count on you taking action!
>Depending on how far you want to with raisng the engine performance,
>you are reaching a point where you may want to take alternative
>paths.
Well, to this I have to say the famous words... I think I'm done on
the performance side when I get the car running smoothly, the current
+260hp is good enough for me and at least for my 9-yearold car...
Yess, I guess that's the case...
>is that they are a piggy-back approach to "altering" the ECU
>firmware or factory progam. In the quest for more power, this system
>of piggy-back workarounds can become a bit of nightmare... unless
>you have a clear idea of your engine performance goals.
Not that I understand the exact meaning of "piggy-back" but I guess
one might wind up a dead-end at some point... the return beeing a
quite expensive one...
>fuel defend, a modified engine map, etc... and a replacement ECU may
>end being the better path.
A silly question at this stage... I assume that a replacement ECU is
not the same as a performance chip (in my case Superchips)???
>>would that still be necessary with the HBC?
>solenoid to waste gate actuator, and not the MAP sensor.
Hell, I'm not sure where it's attached, I'll post a pic when I get
them developed and scanned.
>of the control actuators and feedback loop sensor conditioning, but
>they usually maintain closure of the wastegate at an earlier or
>controllable point of the engine rev range, and open quickly at the
So, do I read this correctly... a manual boost controller like the
Hallman one would not in any way prevent (except for opening the
wastegate of course) the boost from rising too high? This brings
another question to mind, is the actual cut-off caused by the
wastegate opening (this is what I've been told), or have I understood
this wrong also?
I would have hoped that installing a controller (e.g the HBC) would
have somehow controlled the boost in such a way that it's not able to
build up more than one sets it to, I guess I had some false hopes...
Thanks John!
Miki
>paths.
this wrong also?
Thanks John!
Miki
JohnnyG
John Gillon
www.clubsub.org.nz
----- Original Message -----
Sent: Friday, January 12, 2001 2:40 AM
Subject: [BC-BFLegacyWorks] Re: Once more about boost control
In the strict interpretation, piggy-back refers to add-on modules to the
ECU. I use the term for any modification to the original factory control /
feedback loop. eg. a piggyback electronic device that changes the lower or
upper limits of the analog signal output from the MAP sensor "fools" the ECU
into thinking that there is less manifold pressure than there actually is, a
bleed valve in the wastegate actuator "fool" the wastegate to open later
than ECU is telling it to.
The issue, is that these are a workarounds that may have the desired effect
on modifying one portion of the factory program, but inevitably this
introduces other issues... and as more performance is sought, it becomes
time to ditch the workarounds, buy another workaround or a replacement ECU.
ie. money
No, not the same. In my experience, performance chips have also lost favour
to a complete replacement ECU.
OK
> this wrong also?
Correct, boost is primarily controlled by opening the wastegate... there are
other factors, but wastegate gate control is the main one. There are many
boost controllers that provide adjustment or multple settings of the
wastegate cut-off.
It will do exactly what you hoped for.
John Gillon
www.clubsub.org.nz
www.clubsub.org.nz
ie. money
OK
> this wrong also?
wastegate cut-off.
John Gillon
www.clubsub.org.nz
Matt Scicchitano
would
able to
hopes...
> John Gillon
> www.clubsub.org.nz
I may have missed a few things in this topic so forgive me if I
repeat something, but Miki, how is your boost going so high? Do you
have a chip? John pretty much covered everything in detail so just
to add a bit, The Hallman eliminates the factory boost control
solenoid so the ECU has no say anymore when the wastegate opens. If
you want raised boost, but still have the safety of a boost-cut, you
can always get two Hallmans, one for the wastegate and one for the
map sensor. If you want your boost set at, say, 17psi, set the
Hallman for the wastegate at 17psi, and then set the one going to the
map sensor at around 18psi. That way, if something should happen to
the wastegate, as soon as the boost reaches 18psi, the map sensor
will allow the ECU to cut the boost.
FWIW, the Hallmans are noted for their reliability and if you set it
at 17psi, the HBC will keep the boost at 17psi. Is it possible that
you are running so much boost at the moment that the wastegate is
fully opened, but not large enough to expell enough of the exhaust
gas to keep it at the boost you want? Also, not sure what downpipe
you have, but the stock downpipe's path for the exhaust coming out of
the wastegate is horrible at best, thus maybe not allowing the
wastegate exhaust to get out fast enough, and again, the boost will
begin to rise no matter what. This is the reason most of the
aftermarket downpipes have the seperate pipe for the wastegate. All
speculation, but maybe something to think about.
-Matt
would
able to
hopes...
> John Gillon
> www.clubsub.org.nz
-Matt
Miki
--- In BC-BFLegacyWorks@egroups.com, "Matt Scicchitano" <nzwrc1@s...>
> have a chip?
Yes, a Superchips one.
>John pretty much covered everything in detail so just to add a bit,
>The Hallman eliminates the factory boost control solenoid so the ECU
>has no say anymore when the wastegate opens. If you want raised
>boost, but still have the safety of a boost-cut, you can always get
>two Hallmans, one for the wastegate and one for the map sensor. If
>you want your boost set at, say, 17psi, set the Hallman for the
>wastegate at 17psi, and then set the one going to the map sensor at
>around 18psi. That way, if something should happen to the wastegate,
>as soon as the boost reaches 18psi, the map sensor will allow the
Now I'm gettin' really confused, if I install an HBC, does that mean
the boost can climb as high as it gets???? Currently it's cut-off at
~1.4bar (~20psi), that's due to the bleed valve I installed, before
it was cut-off at ~1.15bar (17psi). My goal would be a boost at say
18-19psi tops... but how about the cut-off then, with e.g. an HBC?
Those of you who have experienced it know that it's impossible to
drive a car that's cut-off every now and then when you floor it on
fourth or fifth gear... So, I'd like the car to run with a boost of
around 18-19psi max, the word "max" beeing the important one here...
How can one control that wihtout opening the wastegate (if that is
what happens when it's cut-off... I'm not even sure of that)? Or, is
the problem that the wastegate opens "too much and too fast"???
>Is it possible that you are running so much boost at the moment that
>the wastegate is fully opened, but not large enough to expell enough
>of the exhaust gas to keep it at the boost you want?
This part I don't understand, sorry...
>Also, not sure what downpipe you have...
I have a custom downpipe with sort of a separate pipe for the
wastegate, very much like the picture that someone posted a while
back (although that was from a Impreza IIRC). The entire exhaust is
custom made, and aaaa.. no cat either... so it's quite "free-flow".
If I can't get this working, I'll soon put the original exhaust back,
or then just wait for the summer and warmer weather... then the boost
won't climb that high... that's what I've noticed before... or maybe
I'll order an HBC and mount it and...and... and... hope for the
best...
cheers,
Miki
> have a chip?
best...
cheers,
Miki
JohnnyG
Yes, the boost controller is set to open the wastegate at your target boost
pressure, rather than what you have currently... where the ECU is opening
the wastegate in response to the "fooled" signal from the MAP sensor.
Yes, it is a pain... hitting maximum boost causes the ECU to "kill" the
engine before you have maximum revs / speed.
No, the ECU kills the engine (fuel injector pump I believe)... rather than
opening the wastegate... the same engine cut function also applies to over
rev / speed signals.
> Or, is
No, not in your case with the engine cut occurring because of excessive
boost... but, Yes, this is how the factory ECU controls the wastegate. The
boost controller "snaps" fully opens the wastegate quickly at your target
boost, rather than the factory ECU "progressively" opening at lower boost
pressure.
What Matt is saying, is that even though the wastegate has been opened, the
outlet is too restrictive for the exhaust flow to be diverted completely,
and the turbo is still spinning and boost creep may occur.
The above previous paragraph won't be an issue then.
This doesn't sound logical... it is an effect that doesn't really deal with
the problem.
John Gillon
www.clubsub.org.nz
> Or, is
pressure.
the problem.
John Gillon
www.clubsub.org.nz
Miki
Ok, but... could I use the boost controller to directly LOWER the
boost then, or does the ECU ignore that and build up the boost
anyway? Hell, almost everyone is trying to get their boost up, but
poor me is always the other way around
Regarding the cold/warm climate, John I'm 100% sure that the boost
climbs faster and higher if the weather is a bit colder, at least on
my cars (my previous car was also a Turbo Legacy). With the other
exhaust (almost stock), I'd say the difference was 'bout 0.1-0.2bar.
I've never experienced an engine cut-off during summer time, but far
too many when the temperature drops below 0 degrees (C)!
cheers,
Miki
> >mean the boost can climb as high as it gets???? Currently it's cut-
> >off at ~1.4bar (~20psi), that's due to the bleed valve I
> >installed, before it was cut-off at ~1.15bar (17psi). My goal
> >would be a boost at say 18-19psi tops... but how about the cut-off
> target boost pressure, rather than what you have currently... where
> the ECU is opening the wastegate in response to the "fooled" signal
> > of around 18-19psi max, the word "max" beeing the important one
> > here...
> the engine before you have maximum revs / speed.
> rather than opening the wastegate... the same engine cut function
> also applies to over rev / speed signals.
> > Or, is
> excessive boost... but, Yes, this is how the factory ECU controls
> the wastegate. The boost controller "snaps" fully opens the
> wastegate quickly at your target boost, rather than the factory
> ECU "progressively" opening at lower boost pressure.
> > > that the wastegate is fully opened, but not large enough to
> > > expell enough of the exhaust gas to keep it at the boost you
> > > want?
> opened, the outlet is too restrictive for the exhaust flow to be
> diverted completely, and the turbo is still spinning and boost
> creep may occur.
> > is custom made, and aaaa.. no cat either... so it's quite "free-
> > flow".
> > back, or then just wait for the summer and warmer weather... then
> > the boost won't climb that high... that's what I've noticed
> > before...
> deal with the problem.
> John Gillon
> www.clubsub.org.nz
cheers,
Miki
> > here...
> > Or, is
> > > want?
> creep may occur.
> > flow".
> > before...
> John Gillon
> www.clubsub.org.nz
Matt Scicchitano
--- In BC-BFLegacyWorks@egroups.com, "Miki " <awdturbodude@y...>
> anyway?
Miki, yes, a boost controller will lower the boost right down to
whatever the actual spring tension is in the wastegate( US turbo
springs are about 6.5psi, then the boost solenoid and ECU allows the
wastegate to stay closed, thus rising the boost).
If you are going to use a boost controller, the ECU has absolutely no
control over the wastegate's boost level because you disconnect the
vacumn lines going to it. The boost controller you will install now
has total control in raising or lowering the boost. What I suggest
for you to do is this. There should be a vacumn line on the outlet of
your turbo. Just connect this vacumn line right to the wastegate and
take the car for a drive. This will tell you what your wastegate
spring will open at. It will also tell you that that is the lowest
psi you will be able to run. A boost controller will allow you to run
any amount of boost that is higher then the wastegate spring setting.
For instance, since the US turbo wastegate spring opens at 6.5psi, I
could run 6.75 psi with my boost controller if I so desired.
Just keep in mind, with an aftermarket boost controller, The ECU has
no control whatsoever. The boost controller controls the wastegate so
you can set the boost wherever you like, again, as long as it's not
lower then the actual spring in the wastegate. If you want to run
17psi, the boost controller will allow you to do so. If you want to
run 10 or 11psi, it will again allow you to do so. Whatever you want,
just set it there and away you go.
-Matt
> anyway?
-Matt
JohnnyG
> boost then
Yes. Set it to your target boost.
> anyway?
No. The boost controller has bypassed the ECU's function in controlling the
wastegate. nb. the opening of the wastegate "removes the drive on the turbo"
reducing boost, and the boost controller is now in total control of
wastegate operation.
Yes, this is to be expected. My reference to cold climate, was not so much
referring to your advantage in building boost faster, but more so in your
advantage of a cool intake charge deferring the onset of combustion
pre-detonation... which has allowed you to run extremely high boost
pressures. Seriously... running 20psi in many other parts of the world,
requires race-gas or a copious supply of replacement engines!
I perceive that you are struggling with the concepts of turbo engine
management systems... I will continue on with this thread in subsequent
replies.
John Gillon
www.clubsub.org.nz
> > > here...
> > > Or, is
> > > > want?
> > creep may occur.
> > > flow".
> > > before...
> > John Gillon
> > www.clubsub.org.nz
> boost then
> anyway?
replies.
John Gillon
www.clubsub.org.nz
> > > here...
> > > Or, is
> > > > want?
> > creep may occur.
> > > flow".
> > > before...
> > John Gillon
> > www.clubsub.org.nz
JohnnyG
Whoaaa Matt!, I am not 100% certain but (I could have egg on my face)...
Spring tenson? ECU controlled wastegate don't use springs to control the
wastegate opening, ....the EJ20G uses PWM proportional control of the
wastegate, based on signal from the MAP sensor.
If it was indeed a non-ECU controlled system... "...boost that is higher
then the wastegate spring setting."... you must mean "lower than or equal
to.."?
Hmmm... springs in the wastegate... must be a USA thing.
John Gillon
www.clubsub.org.nz
to.."?
John Gillon
www.clubsub.org.nz
Matt Scicchitano
face)...
the
control the
the
absolutely no
the
now
outlet of
and
run
setting.
higher
equal
> to.."?
. I have always been under the assumption that there is a spring in
the wastegate, even if it is controlled by the boost solenoid. And no
I meant "equal to or higher" let me explain quickly.
The spring in the wastegate on our cars has a tension level so that
if there was no interference at all from any kind of boost
controllers, factory or non, 6.5psi of boost will push against the
spring enough for it to open the wastegate. The boost solenoid is
simply there to try and regulate it at a higher psi(8.7 in our case)
as well as perform the services that the ECU requests such as
lowering the max psi when the water temp gets to hot and so on. I
have disconnected the boost solenoid from my car and simply relied on
the spring to open the wastegate, and I indeed got rougly 6.5psi of
boost.
Now then,in our case, if the spring opens at 6.5psi( again with no
interference from other boost controllers), this will tell you that
if you add an aftermarket boost controller, you will be able to run
6.5psi or higher as it would be absolutely impossible to run anything
lower since if you try to run, say, 5psi, the wastegate will never
open at 5psi because the spring itself needs at least 6.5psi to open.
Also, if you have the turbo off your car and you compress the
wastegate arm with your hand back into the diaphram, when you let go,
the arm immediately snaps back into place( it did for me anyway if I
remember correctly). What would cause the wastegate arm to snap back
into place? I'm pretty positive that there are springs in most
wastegates, factory or non-factory, but I could be wrong.
-Matt
face)...
the
control the
the
absolutely no
the
now
outlet of
and
run
setting.
higher
equal
> to.."?
boost.
-Matt
Matt Scicchitano
no
case)
on
> boost.
anything
open.
go,
I
back
> -Matt
Just to add one more thing here, there are a few Impreza RS owners
over here that are taking the turbos off older Legacy Turbos and
turbocharging their Imprezas. Being that the Impreza in NA, there are
no boost control features on it from the factory whatsoever. However,
they have no problem running these turbos with or without any
aftermarket boost controller, so their must be something in there
providing tension on the wastegate. Otherwise what would actually
snap the wastegate flap open or provide enough tension on it to keep
it closed if the desired boost level is not yet met?
-Matt
no
case)
on
> boost.
anything
open.
go,
I
back
> -Matt
-Matt
JohnnyG
Wow Matt, this is very different to my understanding... I will check this
out and confirm back from an EJ20 perspective.
> And no
I understand your "equal or higher" with this explanation, but I understood
the wastegate actuator to provide direct control.
Yes, this makes sense to me... the spring providing a return action on the
wastegate valve.
> boost.
I understood the actuator provides wastegate "opening" and "closure" at the
ECU determined pressure... the spring is only there to help sealing and
"help" the diagphragm.
What model turbo does the USA model use... an internal wastegate?
Very confusing.. maybe I am in agreement with what you understand?
> -Matt
John Gillon
www.clubsub.org.nz
> And no
wastegate valve.
> boost.
> -Matt
John Gillon
www.clubsub.org.nz
JohnnyG
Ahh... this makes absolute sense then... and is a difference between the
higher boost Japanese models with direct ECU control of the wastegate.
John Gillon
www.clubsub.org.nz
> -Matt
John Gillon
www.clubsub.org.nz
> -Matt
Tommy Moffitt
The internal wastegate on legacy turbos has a predetermined boost level that
it opens at. The wastegate is controlled by the actuator. It is the actuator
which actually has this pre-determined amount set. It may be 6 psi or 7psi
or what ever. The reason you would add solenoids or any sort of boost
controll would be to bleed boost---> otherwise know as increasing boost. You
cannot run boost below the actuator setting because otherwise the actuator
arm will open the wastegate based on its setting.
Clear as mud?
Tommy.
-----Original Message-----
Sent: Monday, 15 January 2001 1:57 a.m.
To: BC-BFLegacyWorks@egroups.com
no
case)
on
> boost.
anything
open.
go,
I
back
> -Matt
-Matt
Clear as mud?
Tommy.
no
case)
on
> boost.
anything
open.
go,
I
back
> -Matt
-Matt
Matt Scicchitano
--- In BC-BFLegacyWorks@egroups.com, "Tommy Moffitt" <tmoff@i...>
level that
actuator
or 7psi
boost
boost. You
actuator
> Clear as mud?
> Tommy.
Not really. What then is actually inside the actuator that is set at
this pre-determined amount?
-Matt
level that
actuator
or 7psi
boost
boost. You
actuator
> Clear as mud?
> Tommy.
-Matt
tmoff@ihug.co.nz
I have never really taken an actuator apart. I have taken turbos apart but the
actuator it self. I figure that they make the actuator stiff somehow so that
for it move you need to apply x amount of air pressure to move it?
Different actuators are set at different levels and not all turbos use the same
actuators.
Also actuators can fail and cause issues with boost or lack of boost.
I know it hasnt helped to much but I will endeavor to get an actuator from a
friend and have a look.
Tommy.
-Matt
actuators.
Tommy.
-Matt
JohnnyG
Yep, this is my understanding... a different action from older, non-ECU
controlled wastegates.
John Gillon
www.clubsub.org.nz
Sent: Wednesday, January 17, 2001 10:47 AM
Subject: RE: [BC-BFLegacyWorks] Re: Once more about boost control
that
actuator
You
> Clear as mud?
> Tommy.
> From: Matt Scicchitano [mailto:nzwrc1@sunlink.net]
> no
> case)
> on
> > boost.
> anything
> open.
> go,
> I
> back
> > -Matt
> -Matt
John Gillon
www.clubsub.org.nz
that
actuator
You
> Clear as mud?
> Tommy.
> no
> case)
> on
> > boost.
> anything
> open.
> go,
> I
> back
> > -Matt
> -Matt
