This is where things get complicated. I am familiar with replacing SVX trannys so I thought I would be able to go about it the same way...hop on a forum, grab a decent tranny for 250 install it and be done with it. I didn't realize how scarce the 3.9 4eat was (at least the turbo version). I called around and looked on the internet, and could not for the life of me find a 4eat from a turbo anywhere.
I am however able to get a hold of a 3.9 4eat from an old legacy L (along with the torque converter) for about 400
Now another layer of confusion comes into play... The guy that sold it to the car dealer said that the reason he wanted to get rid of it was because he kept having tranny problems, and had recently just installed another one, which, although it worked fine the odometer stopped working. So when he sold the car, he asked for the tranny to be pulled and given back to him so that he can return it to the junk yard to get 500 dollars back (what he paid). I talked to him on the phone and he said something about speedometer gear in the tranny being bad or something...
now despite having swapped them, I know very little about transmissions, but this speedometer gear thing doesn't sound right at all, I think maybe there was some other problem with it (especially considering it was the second transmission that had had this problem). Also, another fact that I am not sure about is if it was a legitimate turbo tranny he put back in.
So to summarize these are my main questions.
-Is there really something wrong with the transmission internals to cause the odometer problem and such, or is it electrical/TCU or something else.
-If it is not the transmission internals, do you think it is worth 500?
^^I guess I need to find out if it is a legitimate turbo tranny or not.
-If so should I keep this one in if fixable.
-If not, should I just go with a torque converter + tranny of a Legacy L? And is that really going to run me $400?
Sorry for the incredibly long post, and anyone that takes the time to read it and help me, I truly appreciate it.
-Ben-
