Quick question RE fuel pump replacement
skid542
Post by skid542 »
I just got into work this morning and I've noticed that I'm dripping fuel under my car. I replaced the fuel pump last night - thank you Frank. I suspect I have a fuel line that needs a new clamp or a clamp tightened down but I thought I'd just ask real quick if these cars have a history of doing this after replacement. I don't need a new gasket for around the pump/sending unit assembly do I?
I'll check it out this evening when I go home and tighten any hoses down but thought I'd ask real quick any how.
Thanks.
Lee
gto7419
Post by gto7419 »
I've found that those clamps suck - I would double check them first....
Danny
500cc Shifterkart, 125cc Shifterkart, 01 MX5, 93 Legacy Wagon (DIY Turbo)
The seal around the sending unit should be good.....I've had that damn thing open more times then i can count, and haven't had any leaks there.
Check the clamps on the lines though.
