91 legacy SS part out.....
douglas vincent
Everything is available off of it, EXCEPT motor, front fenders, front bumper
All pricing is PLUS SHIPPING!
Tranny is 5mt $600 obo for the moment
Radiator and remote filler $140
Front and rear brakes, calipers, rotors, and mounts, $125 (worth it!)
Brake booster $40
ECU $75
Rear LSD $100
Motor will be available after rebuild with new Wisecos, ACL race bearings....
The rest of the bits are available, just ask.....
Brake booster $40
ECU $75
Rear LSD $100
douglas vincent
Yes it will come with the axles, whole assembly, However, I may have to cut the trailing arms to get it off easy, let me know if thats a problem.
Pedal assembly available.
Doug, when you say cut the trailing arms off, you mean off the car's suspension? I have a good working open diff and rear end and really just need the LSD diff and the axles so that I can drop the current one down and pull the axles and put the new one in with the axles. I have gotten underneath my SS and really looked at the rear end but I assume it's like my OBW where the diff attaches with a few studs?
Either way, I'd love to take the diff and axles off your hands and I can make it work when it gets to me.
How much for the pedal assy?
The trunk latching mechanism, is it the same between pre and post-facelift? If so I'm also in need of the latching mechanism in the trunk and the bar attachment that is attached to the car. Mine is worn so much that my cable won't actuate it anymore. You interested in pulling this for me?
Thanks.
Thanks.
Lee
Stubs being just the part of the axle that goes into the diff and to the first CV joint?
Guess I need to do some more reading up on all of this.
Either way, just send me what I need and I'll sort it out when it gets here
Lee
starkiller
Did it have fog lights?
If so do you have the panel that the switch attaches to?
