i searched a little but didnt find anything on the site about Loyale (i might know the reason why)
i found a 91' Loyale 4WD 5MT with an EA82
everything is there, and i was wondering if there is a romote posibility that the tranny and rear end and clutch pedel assembly and well, the whole drive train really
would fit into the Legacy to replace my 4EAT
its got a badass 4wd push button on the shifter, does it have a differential or clutches like the 4EAT?
91' Loyale 5MT into a 90' Legacy??
1990 Legacy LS, 4EAT
Manarius
I don't think that the tranny would bolt up without an adapter plate.
alright, i thought it looked a little small
what i really was looking for is a driveshaft, but i just happen to cross upon the 5mt, i have only found 1 4EAT AWD subie, the driveshaft was already taken
beleive it or not, that was the first manual subaru ive ever seen upclose
i need just the carrier bearing really, but its an odd driveshaft ill get a pick of it to explain it to you, its not the original, previous owner put it in i gues
here it is, i think its a one peice, unless there is some way i am suposed to pull it apart, i dont know who would sell a carrier bearing for it anyway since its not original, thats why im just looking for the whole thing
i have been driving with it out for about a week, my dad machined a piece of plastic to use for a plug (holding fluid quite well), and i put the FWD fuse in, only prob has been a lack of traction
what is that called, is it still called a u-joint? i have never seen one like that before
That center cv style joint was found on the 90-91 MY's I believe. I've got a driveline just like that meant for a MT sitting outside my garage. I have been meaning to scrap it because I haven't needed it. The 92 and for sure have the split style drive shafts.
ooo, well thanks for that, all this time i was thinking i was supposed to have a 2 peice, thats what was in the manual as well, also what i saw in the junkyard
lol now i feel slightly embarassed
does it split apart some how? would i have to put some sort of puller on it?
No, I don't believe it can be split apart.
