Problem with my 92 legacy sport!!!
92LegacySpOrT
Post by 92LegacySpOrT »
Hello there ok my car is a 92 Legacy Sport and right at the moment its a crank no start but here is the thing if I put a 30amp in fuse block slot number 2 it blows now this is the fuse slot for the fuel pump and so forth now I put a 60amp in place of the 30amp and it started but blew now i'm pretty sure there is a short some where but i just don't know where to start any good idea's?
yes and i do know the 60 amp was a big no no i just wanted to try to get it home
thanks for your help :D
dropdfocus
Post by dropdfocus »
In the trunk right behind the seats is the location for the fuel pump & sending units. The one you are looking for (fuel pump) is on the driver side. It will be covered by a metal plate. Remove that and you've got access to the wiring for the pump.
Hope this helps ya out.
Jason
You've got a short, as you suspected. You need to measure the amps going across each fused circuit and narrow down where your short is.....
94legacy2.2
Post by 94legacy2.2 »
Also stop putting in bigger fuses, you'll have a fire soon.
im slow---Location:Colorado
Got squirt? http://www.msextra.com/index.php
dropdfocus
94legacy2.2 wrote:Also stop putting in bigger fuses, you'll have a fire soon.
That is very true. You can overload the wire before it takes out a slow burn fuse. This will result in melted wire casing and exposed wires...
Jason
92LegacySpOrT
MY 92 legacy sport problem
Yes I know the consequences of my actions lol I would give reasons but don't have time for them I think this car was mistreated before i got it oh and does any one have any specs so i could trace down this short and I did replace the transmission but i'm not sure if any of the wires for the fuel pump run by it or not cause i was think n a pinched wire but i'm not to sure thanks for all your help you guys are awsome :-D
I'd bet some puctuation would help.
Please look in the stuff you need to know thread.....
http://bbs.legacycentral.org/viewtopic.php?t=14485
92LegacySpOrT
problem with my 92 legacy sport!
You are not the only one that has told me that but I like to think of forms as I/M's so I use them like one besides your brain should fill in the puctuation any ways lol :-D
ultrasonic
Re: problem with my 92 legacy sport!
Post by ultrasonic »
92LegacySpOrT wrote:... I like to think of forms as I/M's so I use them like one besides your brain should fill in the puctuation any ways lol :-D
Punctuation, like spelling and grammer, is a tool to help people communicate effectively. It's a way to get what you want. You want people to give you information, in this case about your car. The better you communicate your idea, the more likely you will get what you want.
Not using the communication tools you have at hand is like changing a tire using only a screw driver. You've got the correct tool right there in your tool box, but for some reason you think it's cool to not use it.
If youput the workload onme the reader to fill in the puctuation when imreading the forms youwill not get any helpful information from me anywayslol
-steve-
03 Legacy L Wagon
91 Legacy Sport Sedan - SOLD
dropdfocus
So beautifully said Steve. Bravo!
Getting a point across in a clear manor allows for a clear and most times a correct response to your issue at hand.
Jason
kleinkid
Post by kleinkid »
555BCTurbo, you gotta love this!
92LegacySpOrT
LOL well it's a proven fact that your brain will fill it in if your going to stop and think about where the question mark goes and where the comma goes then you don't process info that fast but oh well if that's what you want I guess I can give you that next time I write i'm not stupid just lazy and to use to I/M's but thanks I did get what I need that link helped alot :-D :smt101 :smt019
92LegacySpOrT
Problem with my 92 Legacy Sport!!!
Ok so here is the news after everyone pitched in there know how and info. Today I was playing with the wiring harness right. The one that goes form the fuel pump and then to MPFI control unit. So anyways I bought a new 30 amp fuse and put it in where it goes. Then I hooked everying that i had taken apart back together. So the next thing I did was turn it over. Guess what? It started so anyways I was doing my checks jiggle n the wire's and so forth. Then the car started to die. So I guess i'm replacing a harness. Yahoo go me lol but I guess that's what I get for getting it for free. After fixing to car's anyways I really love this car. So I really don't want to part with it. Well thanks for all your help if you think my diagnosis is wrong feel free to tell me. :lol: :-D :wink:
