An ECU scan tool for turbo and NA owners
I'm having similar problems as IronMonkeyL255. My notebook is an IBM T23 1.13GHz. I was using a Dell Latitude from work with version 0.5 successfully, but moved and had to give the notebook back. I bought this T23 expecting it to work, but was surprised to find neither version 0.5 or 0.6 works. I have successfully shorted the send/receive leads on my cable (using a paperclip) to get 00:ff:ff. When hooked up to the ECU it seems to sit and wait polling for the ECU ROM ID. I wasn't even getting the shorted 00:ff:ff until I switched the BIOS ports/IRQ as IronMonkeyL255 mentioned....
Any leads on these issues?
Cheers
-Jeff
Cheers
-Jeff
No response using 0.6 but 0.5 works fine.
I could not get version 0.6 to talk to my 1990 EJ22 but after reading this thread I saw the comments about trying version 0.5.
So I did and it works fine. Version 0.6 hangs at the read ECU revision screen (as if it wasn't hooked up).
Using an old Toshiba 4100 laptop and Paralled cable.
Just thought you would like to know.
Paul C.
Paul C.
Suby-vanagon EJ22
Alright, finally got my connector made. Unfortunately since I'm using a old ass laptop, the battery is dead so I can't drive around and monitor values. I did drive around town to get the car warmed up, then sat in the driveway idling.
Tried the 0.06 version but it would hang on reading my ROM (72.36.22). The 0.05 one worked fine though. Since I'm unfamiliar with the various ranges of the parameters, would someone look them over and give some feedback?
Idling:
RPM 625-700
Coolant 192-203F
Ignition Timing 15
Airflow 1.04-0.98v
Load 39-42
Throttle PS 4.68
Injector PW 2.4-2.6ms
IAC duty 0.365
O2 0.04-0.8v
Fuel trim -1.56-2.56%
Timing correction 0
Boost control 1.56%
Bar pressure 663.75 torr
Boost/Vac -18 inHg
Reving: & holding to around 3-3.5K
RPM
Coolant
Ignition Timing 47
Airflow 1.9v
Load
Throttle PS 4.2
Injector PW 2.1-2.3ms
IAC duty 32.50%
O2
Fuel trim 3.12%
Timing correction
Boost control 93%
Bar pressure
Boost/Vac
1) Is the O2 sensor ok? Seems kind of low, or would that change more while driving?
2) The barometric pressure was reading at 663.75 torr, which is 12.82 PSI. I'm at ~4300 ft. Since I'm don't have a FCD installed, that basically means I'm not going to be getting any boost up here?
3) How are the other values?
Idling:
RPM 625-700
Coolant 192-203F
Ignition Timing 15
Airflow 1.04-0.98v
Load 39-42
Throttle PS 4.68
IAC duty 0.365
O2 0.04-0.8v
Timing correction 0
Boost control 1.56%
Boost/Vac -18 inHg
RPM
Coolant
Ignition Timing 47
Airflow 1.9v
Load
Throttle PS 4.2
IAC duty 32.50%
O2
Fuel trim 3.12%
Timing correction
Boost control 93%
Bar pressure
Boost/Vac
'11 WRX Limited
'94 TW | R.I.P.
ROMID for MY97 Forester STB?
Hi all,
Great program you've put together, I have a MY97 Forester ST B with the Jecs Unisia 22610 AD410 ECU. Trying the turbo series ROMIDs but no luck reading data from ECU as yet. Anyone got the ROMID and parameters that could get me reading?
Thanks again.
Thanks again.
Subaru's part catalog says 22610 AD410 is not a valid part #.....
So I went through the process of wiring my car to use this tool. I didnt really make an adapter, although I did goto to radioshack and bought a 25pin connector. I just ran some wire to the diagnostic port, and used some crimp on connectors and placed them into pin 2,3 & 9... then ran the wiring behind my stereo console and installed the 25pin connector in my glovebox. I have a printer extension cable I then connect to the glovebox and run to my laptop, everything looks slick and out of the way...
So that was the hard part (so i thought). I copied the .com file to my laptop, setup a boot menu where I can bypass Win98 and have to load B10Scan in DOS Mode, and fired away. Nothing, it hung at the "reading ROM ID" screen. As agrivated as I was, i checked my LPT settings in the bios, and played with everything. I couldnt get anything to work.
So i called Ryan and asked if I could come over and use his adapter he made (which we have used in the past and has been verified to work). I get to his house, plug his adapter into my laptop and still nothing. So I deem the laptop to be defective and shrug it off. 10min later his adapter fell apart and we were unsure if it was even working properly when we tried. So i came home today and used my multimeter as a continuity tester. I verified I had continuity from the diagnostic cable to the end of the printer extension (the very end that plugs directly into the laptop) and everything tested okay. No reason the wiring should be faulty.
I read every page of this thread, and found others were having problems with version 0.06 and sucess with 0.05. So I downloaded v.0.05 and ran it and BINGO IT WORKED!
So, im not sure whatsup... but 0.06 doesnt seem to communicate with my ECU. I read the release notes and i dont think there is anything in 0.06 that i really need that 0.05 doesnt have. Im trying to use this tool to help diagnose my poor fuel mileage.
Just thought I'd let it be known.
-Brian
-Brian
1983 Subaru GL-10 Brat
1986 Toyota 4Runner
1986 Toyota 4Runner
Yes you have a different ECU then the USA Legacies.
The overseas models had completely different engines, so the air fuel ratio curves, timing, etc are going to be different.
Yes the overseas models have more power. The stock power level on the USA turbo legacies was 165 hp.
Anyone have an idea why some laptops don't completely work with the b10scan?
For example, I borrowed a Gateway Solo 5300 and it could most often read my rom id, but thats it. Very rarely would it be able to read any other parameters. Didn't matter if I changed the BIOS between ECP, EPP, or bi-directional. Same results between 0.5 and 0.6. I tried two Solo 5300's.
When I tried a Gateway Solo 2500, it worked just fine. Used the same bootdisk and cable for both tests. Unfortunately the 2500's battery is dead so I can't drive around with it, while the 5300's battery is great
![Sad :(](./images/smilies/icon_sad.gif)
'11 WRX Limited
'94 TW | R.I.P.
