Has anybody had any problems with their gearbox or clutch? What is the normal life of these items and if they need replacing is it possible to upgrade? Also, what type of gear oil and differential oil is best?
Ross
<http://us.a1.yimg.com/us.yimg.com/a/ya/ ... uldbe1.gif>
Do you know the name you want? Enter the domain name below and press GO!
www.
Yahoo! Domains <http://us.a1.yimg.com/us.yimg! .com/a/ya/yahoo_domain/domains_H.gif>
<http://us.adserver.yahoo.com/l?M=176325 ... =793164420>
RS Gearbox
JohnnyG
RS Gearbox
The standard clutch and gearbox are the weakest links in a turbo Legacy, but
life expectancy is entrely dependent on driver style.
The clutch in particular does not have sufficient clamping pressure to
withstand high rev standing starts, and will slip til you back off the revs.
The gearbox gear set will eventually "explode" with regular "clutch dumps".
The gear box can use conventional hypoid or synthetic oils as the centre
diff viscous coupling is a sealed unit. The rear limited slip diff uses a
viscous clutch pack which requires hypoid oil only.
John Gillon
www.clubsub.org.nz
----- Original Message -----
To: <BC-BFLegacyWorks@yahoogroups.com>
Sent: Wednesday, January 31, 2001 11:50 PM
Subject: [BC-BFLegacyWorks] RS Gearbox
Ross
eGroups is now Yahoo! Groups
Click here for more details
http://click.egroups.com/1/11231/0/_/_/_/981012392/
John Gillon
www.clubsub.org.nz
Ross
Ross
RS Gearbox
Ross
www.
Ross
www.
TurboSubie91@aol.com
RS Gearbox
I have a problem with my second gear grinding. If you go slow enough it wont
grind but when your trying to accelerate quick, you can feel and hear it.
Ian
91 Legacy Turbo
http://click.egroups.com/1/11231/0/_/_/_/981069553/
Ian
91 Legacy Turbo
Barrett, Sam
RS Gearbox
First thing I would do is change your tranny fluid and look for filings.
Either way you're going to have to drop the trans to fix something like that. Don't forget to change the clutch pad when you do. The pad only costs a few bucks and you'll really kick yourself if you have to pull the whole $%^^)_@ thing just to change a $20 part you could have changed at the same time just a couple years (depending on mileage/driver type) ago (retrospectively) when you pull it to fix that gear.
My $0.02
-Sambo
-----Original Message-----
From: TurboSubie91@aol.com [mailto:TurboSubie91@aol.com]
Sent: Thursday, February 01, 2001 3:11 PM
Subject: Re: [BC-BFLegacyWorks] RS Gearbox
Ian
91 Legacy Turbo
<http://rd.yahoo.com/M=176325.1307935.29 ... omains.com> <http://rd.yahoo.com/M=176325.1307935.29 ... omains.com>
www. .com
<http://us.adserver.yahoo.com/l?M=176325 ... =504672419>
My $0.02
-Sambo
Ian
91 Legacy Turbo
www. .com
Rod
RS Gearbox
I would first change the oil and check the sump plug (magnet) for iron
filings.
Rod
Sent: Friday, February 02, 2001 10:10 AM
wont
> Ian
> 91 Legacy Turbo
http://click.egroups.com/1/11231/0/_/_/_/981092817/
filings.
Rod
wont
> Ian
> 91 Legacy Turbo
nue s
RS Gearbox
I had this problem a while back when I put mobil 1 in my 91 legacy
turbo. Changed back to standard Valvoline and the problem is much
better. If I am changing gears, I still feel the teeth catching, but
I just assume that it comes with having 168k on the car.
nue
iron
> filings.
> Rod
> From: <TurboSubie91@a...>
> To: <BC-BFLegacyWorks@y...>
enough it
> wont
hear it.
> > Ian
> > 91 Legacy Turbo
http://click.egroups.com/1/11231/0/_/_/_/981136823/
nue
iron
> filings.
> Rod
enough it
> wont
hear it.
> > Ian
> > 91 Legacy Turbo
jason grahn
RS Gearbox
Boy, I'll say! When i shifted your car from 4th gear at 95mph into 2nd to
slow down for that cop........... just kidding!! hehehe... Ian - email me
off list, got good news!
but, yes, i have felt that grinding that your car gets, have you changed
your gear oil since you've had it?
jason
>Reply-To: BC-BFLegacyWorks@yahoogroups.com
>Date: Thu, 1 Feb 2001 18:10:50 EST
>wont
>Ian
>91 Legacy Turbo
_________________________________________________________________
Get your FREE download of MSN Explorer at http://explorer.msn.com
http://click.egroups.com/1/11231/0/_/_/_/981148642/
jason
>wont
>Ian
>91 Legacy Turbo
