steero antenna wire in the dash
dirtyhandssubaru555
Post by dirtyhandssubaru555 »
i need to know witch color the wire is for my antenna signal wire in the dash, if you understand what im saying. the previous owner didnt have it hooked up so the antenna didnt come up when you turned on the car and i have no idea what wire it is
my girlfriend finaly found out that i spent more money and time on my car then her. she was kind pist to say the least.
92ss, tdo4, wrx stage 1 clutch and 9.5 pound flywheel, sti springs, k&n panel filter, desnorkus
86 gl hatchback rip
87 gl10 rip
stipro
Post by stipro »
The wire should black w/green tracer.
Its pin 6 in the 6pin male plug.
Hope this helps.
dirtyhandssubaru555
connetors are hacked up already.
86 gl hatchback rip
87 gl10 rip
stipro
Post by stipro »
stipro wrote:The wire should black w/green tracer.
Hope this helps.
Did you find the wire??
dirtyhandssubaru555
yep found it and found out y it wasn't hooked up, its about half broke by the sound
86 gl hatchback rip
87 gl10 rip
