(Aust Spec) Liberty RS Turbo Gearbox Problems
Locked
Chris Bresnehan
Post by Chris Bresnehan »
Hi All,
A while back I was suffering some gearbox problems (crunching in 2nd and 4th), even after changing the gearbox oil from the standard stuff supplied by the dealer to Amsoil.
Eventually this was temporarly solved by replacing it again with some Castrol 85W-140 Truck transmission oil and a couple of tubes of Nulon G70.
These days the gearbox is really showing signs that it is on the way out and I am looking into the possible upgrade solutions available to me before it lets go in a big way and leaves me stranded. Given that I am located in Tasmania (Southern state of Australia) I would prefer options that can easily be done locally.
Is it possible to replace the standard Liberty RS Turbo gearbox with the stronger MY99 WRX version? as I am already running a heavy duty MY99 Clutch from MRT and an MY99 spec lightened flywheel. If so , would it even possible to replace it with a jap spec Sti version with the adjustable centre diff?
Any comments or recommendations would be greatly appreciated.
Cheers
Chris
RS1993
Locked
