92 Legacy Sport Ground locations?
92LegacySpOrT
Post by 92LegacySpOrT »
Does anyone happen to have the ground locations for a 92 Legacy Sport? Thanks
I think they should be in the back of this manual
http://www.main.experiencetherave.com:8 ... nual_scans
Or you can look at the 90 manual...should be similar
http://www.main.experiencetherave.com:8 ... agrams.zip
92LegacySpOrT
I could not find....
I could not find anything on the 90's link you gave me for ground location's. The other link did not work at all. You know what i'm talking about right you know when it give you a list and has the ground number and where it is ground at. Thanks for your time.
go to the first one and click on the link
1992_FSM_(Engine_&_Electrical)
92LegacySpOrT
Ground Location?
Hey Josh you know the that wiring harness that I keep talking about under the intake? Well the links you gave me I found the ground location for that harness. But I can't find the ground anywhere coming out of that harness. Does the turbo model have that ground cause if so that might be my problem well part of it anyways.
The intake manifold wiring harness grounds to the intake manifold on the driver's side rear intake runner at the bottom.
Is that what you were asking about?
92LegacySpOrT
Yeah that's it!
Yeah I can't find that ground wire anywhere on that harness
