Speedometer doesn't work and more
Trying to figure out a non-working speedometer on my 92 Turbo.
Subaru's VSS system seems wacky to me. There are 2 VSS sensors one cable driven and one electrical? The cable one goes straight into the gauge cluster, so this is the one I should be looking at right? Does anyone know what are the typical problems I should be looking for? I already made sure the cable plugs into the cluster tightly (it was a bit loose before).
I also have shifting problems, AWD doesn't work, ABS light is on. Could these all be related to the VSS?
I'm going to guess you have an automatic.
The base piece that connects the cable to the trans is a common failure point.
http://www.main.experiencetherave.com:8 ... lebase.jpg
If the speedometer is slow to react or just slower than it should be in general, the cable should be greased. I was driving along the Interstate when my speedo cable broke... yea that was a lot of fun.
'11 WRX Limited
'94 TW | R.I.P.
No....these wouldn't really cause your speedo to read fast if you're driving at a steady speed.
What size tires do you have on the car?
The odometer & speedo are being fed off the same input, and the speed sensor is in the combination meter (cluster).....so that's not going to change anything...
if the speedo and the odo receive the same input and only 1 is wrong then the input shouldn't be the issue, rather the issue is within the speedometer itself. that's my take on it now that I think about it a bit more and you have confirmed they both receive the same input. That make sense to anyone but me?Legacy777 wrote:The odometer & speedo are being fed off the same input, and the speed sensor is in the combination meter (cluster).....so that's not going to change anything...
94 BC w/ AWD Sold 6/25/08
92 BJ Rust bucket gone
90 BC (I think) Stripper, gone since 2k
86 GL10 Turbo 4wd, Gone since 99
The odometer motor & speedo assembly are all driven off the same stepper motor & electronics. Changing out the speedo isn't going to do anything.
I think I have a diagram that shows that, but it looks like my servers went down due to a power outage. I'll have to check them when I get home, and post later.
I'd like to see that diagram. there must be some point where they diverge and that is where the problem lies.Legacy777 wrote:The odometer motor & speedo assembly are all driven off the same stepper motor & electronics. Changing out the speedo isn't going to do anything.
I've got no other clues than to blame on something internal to the cluster at this point.
Hmmm I can't seem to find what I'm looking for.
I'll have to dig into the paper manuals when I get home. Shoot me an email to remind me. I'm heading out of town tomorrow until Friday, so hopefully I can find what I'm looking for.
