Any Cams available?
Ej22TIM
Any Cams available?
Post by Ej22TIM »
are there any cam options for my stock turbo heads or do i have to have them sent out to have ground down?
Post by 555BCTurbo »
Pretty much the only option is to send them to Delta cams and have them do a regrind
Ej22TIM
Post by Ej22TIM »
has anyone gone through these people? what kind of prices? and whats the turnaround rate?
thanks
Tim
dropdfocus
Post by dropdfocus »
Jason
Ej22TIM
Post by Ej22TIM »
i just talked to someone there, they said 72.50 for each, the lady said there was 2 grinds they offer, one is more of a street setup, and the other is what she said was a "hot street" grind.
for the more agressive grind would i have to get stiffer valvesprings? i guess i just want to know more about this
thanks,
Tim
Tim
93 Legacy SS Winestone 5mt swapped
Megan Racing Bellmouth 13psi
WRX Intercooler and Hoodscoop
JDM ej20G DOHC head swap, wiseco pistons and td04 in the making.
dropdfocus
I would believe so, but it would be best to confirm it with the shop doing the work. As for pricing, that's not bad at all! I may just have to send off my cams from my DOHC heads so the turbo motor is a bit "snottier". $290 is much cheaper than $499 for the Cobb cams (Impreza 25RS).
Jason
Ej22TIM
Post by Ej22TIM »
they said it would be a 1 day turn around also which is sweet!
Tim
Ej22TIM
Post by Ej22TIM »
so does anyone know for sure weather or not i need to get some stiffer valve springs? i am going with the mild street setup.
also, correct me if im wrong but i can do cams with the engine in and the heads on correct?
Tim
bmxpunk
Post by bmxpunk »
It will be really difficult to do them in car. ONe cam comes out the front of the head the other out the back.
shouldn't need stiffer springs.
I loved mine when they were on my car
2011 Mini Countryman S All4
1970 Honda Ct90
2001 Forester S of Doom - mowed down by a Cummins
1994/5/6/01/02/03/04/06/07/08 Impregacy OUtback SS STi Type R money pit- NEW RALLYCAR!!
dzx
Post by dzx »
yeah, did this a long time ago. The cams move the powerband up and it really helps to have a turbo that doesn't die off at higher rpm. I dont think you can do the cams with the heads on the engine because there isn't enough room to pull the cam facing backwards out of the head.
///M
'93 Legacy SS - part out
Legacy Rally Guy
Post by Legacy Rally Guy »
I have my heads all cleaned/planed... and sitting in my trunk, I'm just waiting for a few last engine things... What else do I need to make my tappers lift? *sorry bad joke* anyhow, would I need different lifters, rockers, fulcrum?
Ej22TIM
Post by Ej22TIM »
i hear stock ej22e cams are a decent upgrade over stock, can anyone verify this?
Tim
I sent my cams to delta before I put my motor together. I think I have the "hot street" grind. There is a slight lope at idle. Depending on the weather, I have to keep it a bit rich at idle since there is some exhaust gas reversion.
I couldn't tell you the difference they made since it all went together at once.
