Jeff
aftermarket aluminum radiators...
rockethound
I didn't see this anywhere else, so I'll get on with the details. I cracked a radiator tank last week in Redmond at the Subiclub meet. I JB puttied it and it got me back to Mount Vernon. I ordered up a new Koyo aluminum radiator for the legacy SS since the old one was toast. Here's the bad part...
I noticed right off when the Koyo arrived that it was more than double the thickness of the stocker, that little voice in the back of my head started mumbling about that but I didn't quite catch the point of it, I was thinking that the extra cooling capacity might cause a cel due to the extra cooling but I figured that this thing should never overheat again with this radiator... heh, now the fun part: Most if not almost all auto cooling systems appear to have the thermostat on the coolant outlet, BEFORE the radiator so it senses the temp in the engine, it appears that Subaru places the thermostat on the return line to the waterpump AFTER the radiator. I'm sure everyone knows where I'm going with this. The thermostat in a Subaru is rated at 172 deg F. but the water exiting my shiny brand new Koyo aluminum radiator was probably 165 deg F... as a result, the thermostat never reached it's operating temp and failed to open. to finish, I had to have the car towed home, it started once it cooled down seems to run fine except for the cel's I was getting one for ect sensor, iac and knock sensor. well, the engine got so hot that it melted the plastic jacket of my knock sensor. "like candle wax" so I think the ect got baked too. I replaced the k/s and the car seems to run ok but I can't be sure that nothing else got soft damaged so, I guess it's time to start collecting engine parts just in case
I guess the main point of this is maybe there should be a sticky somewhere about thermostats and aftermarket radiators. By the way, I installed a 160 deg F Coolsafe thermostat from Crucial Racing so if it overheats again, the thermostat will fail in the open position instead of closed.
Jeff
Jeff
'92 Legacy SS ej20g mugged, desnorked, TD04, , MBC, CAI,v2 i/c, JDM STi v2 close ratio 5sp w/4.11's, short shifted.
douglas vincent
Did you burp it first?
IMO the radiator had nothing to do with the failure. The thermostat gets its heat from the block, not the water coming through the radiator. Think about it, stock or not stock radiator, the water coming out of the radiator is ALWAYS cool. The coolent coming OUT OF THE RADIATOR is not what causes the thermostat to open. Its the hot water on top of the thermostat INSIDE THE BLOCK that causes the thermostat to open.
I suspect you either had a bad thermostat, or didnt burp the system, or correctly fill it.
Yeah, I agree with Doug - the radiator didn't have anything to do with it unless it was defective. You should have had an eye on the temp gauge before it got that hot. The only bad design in this cooling system (which is usually very bulletproof and far better than most) is a consequence of the engine type - the pocket above the water pump can collect air in the system and prevent the pump from circulating. Burping the system is absolutely critical and I usually have to do it several times after changing radiators in and out and driving it on short trips. Bad head gasket can cause this as well. I'd replace those HGs and change the oil due to the heat that engine experienced. Make sure you check everything for warpage.
rockethound
Alum, radiator
Doug,douglas vincent wrote:Did you burp it first?
I burped it for 15 min with the cap off, the heater controls on hot and the burping vent on the radiator opened. It should have been well burped. I also checked the thermostat using a double boiler on the stove, checked it 3 times letting it cool each time. it opened consistantly between 171 and 172 deg. my temp gauge was bad so that part was my bad, driving without a good gauge.
Jeff
rockethound
evolutionmovement,evolutionmovement wrote:Yeah, I agree with Doug - the radiator didn't have anything to do with it unless it was defective. You should have had an eye on the temp gauge before it got that hot. The only bad design in this cooling system (which is usually very bulletproof and far better than most) is a consequence of the engine type - the pocket above the water pump can collect air in the system and prevent the pump from circulating. Burping the system is absolutely critical and I usually have to do it several times after changing radiators in and out and driving it on short trips. Bad head gasket can cause this as well. I'd replace those HGs and change the oil due to the heat that engine experienced. Make sure you check everything for warpage.
I,m going to keep an eye on the temps and oil for possible H/G damage, It's been checked before each startup and so far the levels have been good. Bad oil's out and new oil's in I just hope the bearings are ok as it did get hot enough to melt the plastic jacket off of the knock sensor
Jeff
Burping takes more than one shot in all cases I've experienced. The air bubbles collect in various spots and it requires varying loads to move them into the radiator where they can be removed. It also helps a lot to squeeze the hoses.
First you replace a radiator because it cracked, but don't try to discover the cause, then AFTER massive overheating, you test the thermostat, see that it opens, and replace it anyway with an overpriced item. That says to me that you don't really know what you're doing. I'm just trying to help by giving real car experienced advice, so I don't appreciate the attitude. I've worked on cars my whole life, and boats for a little while. Doug's done much more and fabbed a supercharger and turbo system all on his own, not by reading what some kid wrote on NASIOC who probably had mommy pay for everything he had done to his car. I would think a guy with a cooling system problem would check into getting something as simple as a gauge working.
rockethound
At 45 years old, I've been doing this for quite awhile, the radiator tank cracked due to 267,000 mi of various hard use. I've changed many thermostats on many different makes and never had a problem. This was the first time on a subaru. I Never make mistakes twice. I've had 4 Subaru's since '93 and never had a problem on any of them except for bad clutch on the '98 RS. I've been building hot rods and high performance vehicles since I was 15, so experience is not the issue either. Nor do I flame others over their mistakes, I look at it as live and learn. If you don't learn from your mistakes and avoid them in the future then you really have no one else to blame for them eh. As far as the folks on NASIOC, this BBS is affiliated to some extent and alot of the people on it are for the most part co-members. There is alot of good experience and good information to be found on this and other BBS and not all of it seems to make it to everyone unless you look.
As far as the rich boy and daddy's money, I do not have a comment there as that again is a flame job; hoever I can say that there are obviously other people who have had the problem because that forum was fairly long and had some well established and respected members names on it. Now, before we slam someone who has made a mistake and posted it for others to read AND LEARN from, maybe we should just leave the flames out of it and take it as what it is...information and if a calm and civil comment cannot be made, please reserve the bandwidth for those who can.
By the way, my first hotrod was a '70 Mustang with a 450HP BOSS
351 which I built by myself with my own money when I was 17.
I welcome constructive comments and suggestions but prefer to pass on the destructive comments.
Thanks,
Jeff
Thanks,
Jeff
We get a lot of people on here now that are kids and have really no clue at all, so maybe I overreacted to your sarcasm, but all I can go by is a response, which sucks compared to when you talk to someone in person. Things can get easily overblown especially when I've been a bit ticked off in general lately. I hope that my more constructive advice can help.
douglas vincent
Jeff, not to fight, but rather to debate.
The water flow is left to right, as you look at the engine bay. The water flows out the top left of the radiator, through the block, hits the water pump and at this point, is constantly pumped through the heater hoses and interior heater core, and when the water is hot enough, the thermostat opens and back out the LOWER section in the the lower radiator hose. The thermostat is in CONSTANT contact with the block coolant. Think about it. The water pump, which contains the thermostat, is constantly pumping the heated coolant through the heating system, EVEN IF THE THERMOSTAT HAS NOT OPENED!
rockethound
Doug,
both my haynes and my chilton guide shows the coolant flows out of the engine through the water passage beneath the intake manifold, into the radiator through and out of the radiator thru the bottom hose and back into the waterpump via the thermostat housing. They can't both be wrong. I know it sounds backwards(and it is
) I don't have access to a factory set of service manuals for my Subie's but the page in the chilton guide is 1-41 and the pages in the haynes guide are 3-5 thru 3-6. they call out the upper right radiator hose as radiator inlet and the lower left hose as radiator outlet. looks like it did warp one or both heads though, as it is blowing bubbles into the coolant overflow bottle when I blip the throttle so, I may have to pick your brain when it comes time to take this thing apart. I've followed the twincharging post so it looks like you definitely know your way around the insides of the ej series motors.
thanks,
Jeff
Jeff
thanks,
Jeff
Jeff
To add to the observations....
The waterpump is a centrifical device. It basically slings water from the center to the outside. The housing has passages cast into to perform these functions.
If you look at a ej22t water pump, which I just did, the thermostat housing is clearly directed into the center of the impellers. The cavity around the impellers (which looks very much like a turbo housing) is also very clearly directed into the void on the front of the block. This area directly feeds a large galley that crosses to the other case half.
So, as much as I know that Doug knows his stuff, in this case I believe he is wrong. The cooling system goes ...thermostat>lower block> upper crossover pipe> upper radiator> lower radiator> back to thermostat.
However, what is correct in previous posts is that there IS always water circulating just behind the thermostat from the heater circuit and the oil cooler circuit (if equipped). The 'sensor' part of the thermostat is also directly in this constantly flowing coolant.
So as long as the pump is pumping (not vacuum locked or broken) and the system is properly full, the thermostat should open properly.
One possible problem I can see is a plugged, missing or capped heater core. If the heater core loop is taken out of the system THEN there is a strong possiblity of no coolant flow, and no thermostat opening because of it. Also a removed heater core should be bypassed and not capped.
Another possible problem can be a thermostat installed with the 'sensor' side installed backwards, twords the hose and not the block as it should be.
rockethound
heh, oh boy, the heater worked great, that's why I pulled over when it started blowing cold air. I don't have a dismounted waterpump handy but it's got to have some method of circulating water across the element while it's closed. I can't figure out why it would overheat like that when I doubled or tripled the cooling capacity of the radiator. I just keep coming back to the cooled water returning from the radiator. I think I'm going to take a break from thinking about it for the night, it's giving me a headache.
Jeff
Jeff
douglas vincent
Well, they are....
In fact, if you look at the upper crossover pipe, it will have an arrow pointing in the directioin of water flow.
Also, look that this picture, they are of an NA and Turbo model waterpumps.
The part of the thermostat that contacts the hot water and opens up (the spring) is INSIDE the waterpump, where the hotwater is, not OUTSIDE, on the radiator side.
Also note the output line for the heater core, and in the turbo case, the output line for the oiler cooler.
douglas vincent
Also, the rotation of the gear is counterclockwise, which forced the water OUT the heater core line, and the thermostat when open.
IronMonkeyL255
I hate to say it, but the FSM agrees with the fact that water enters the radiator at the top and exits it back into the water pump through the thermostat.
Rio Red '91 Legacy SS
Direction of rotation means little. The coolant will flow from the inside of the wheel to the outside. Many water pumps don't have any 'spin' on the vanes at all. It seems like the curves on the impeller would 'scoop' water from the edge to the center, but it's simply not so. While that might work at very low speeds at high speeds centrifical force most definately moves coolant center>outside.
Think about what happens to your boy on a merry-go-round at the park. Same principal.
Now pull out one of those thermostats and see where that reservior connects in relation to the impeller. The thermostat cavity dumps water to the center of the impeller, hence it must be the 'in'. Next time your about to pull a motor, pull the upper hose and crank it. See if the coolant comes out of the block or the radiator.
Either way.. we agree that the 'sensor' side of the thermostat is always in contact with flowing coolant when everything is operating correctly. Hence, I still believe a better radiator cannot cause overheating in and of itself.
douglas vincent
OK, I could be wrong. I will check tommorrow. But I made a pretty good Devils Advocate if I was wrong. hahah.
One more reason I am/was sure of the flow direction is because I have held the lower hose and the upper at the same time, and because the lower hose is cold, and the upper hose is HOT, I assumed the hot water up top would have to flow through the radiator to cool down and enter the block through the waterpump. But now as I type this, I realize my error, for if this were true, then the cooled coolent would suddenly be forced through the heater core and the heating system would suddenly suffer!
But I am still checking in the morning!
I have to agree with Doug on the thought that the new Radiator did not cause the overheating problem.
I have a '99 Impreza with a Koyo radiator on it & never caused a CEL on its ultrsensitive OBDII system (that once thru a code for fuel temp...).
The Koyo was about 4+ x as thick as the N/A Impreza core, & causes the temp to drop to 13x* in the winter on the highway @ 65+MPH.
Summer HW @ 65+ MPH = 150's - low 160's.
It also stopped the coolant temp creep I was had under boost....
I actually had a problem with my Crucial Racing t-stat, causing the car to run hot on the highway & normal in the city.
Took that piece of junk off, put on a stock t-stat & had no more problems.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
96 Impreza OBS
99 Impreza OBS-T
douglas vincent
Well, I couldnt prove to myself that the flow is reverse of what everyone is stating, so odds are high that I am wrong. I admit it.
It sounds like you might be getting air pocket cavitation. If the pump is working (which it likely is), try pulling the T-stat altogether and see if the problem returns. If it does, it's highly likely the air bubbles you're getting from the bad head gaskets/warped heads/etc. are collecting at the impeller. If you're getting that much air in the system it might not matter, but steady-state engine speed is the killer, varying engine speed and occasionally stopping to squeeze the bottom hose seems to displace the air from the cavity a little, but that only gets you so far.
rockethound
Is it possible that I popped the head gasket(s) first , leading up to this unfortunate debacle? 265,000 mi on a turbocharged engine and all probably had something to do with it. I do know that it had never overheated prior to this. Boost has been at 10lbs for al least the last 90,000 mi without a hitch till I installed the I/C but it's still running @ 10 lbs.
Jeff
Jeff
That would be my guess and the subsequent overheating made it much worse. I noticed these cars don't usually give real obvious clues when they start to go like some cars do. Usually you just get some oil in the coolant, but the times I've seen it, it looks like it could just be corrosion from an old radiator - I've never seen it get that chocolate milk look and never seen signs of coolant in the oil. By the time you see air bubbles in the coolant, it's probably been gone for a while. On the one hand, it lets you drive the car with a bad HG for a while with little trouble, but on the other hand, you might not realize there's a problem with the damn thing until it's REALLY gone and you're on the side of the road swearing.
Definitely. You can't get anything less than an OEM thermostat. Maybe some high-end stuff, but no generics - it's not worth saving $8.
