jdm BC tails + rear garnish pics
one of many jdm parts i got (my other goodies are top secret right now ).
if anyone was curious as to what the difference is bewteen the usdm ones... like nearly all japanese taillights there is no side reflector on these. that's it. looks much better IMO
1994 SS "JDM-OEM"
1994 gt wagon, next build
1994 turbo wagon
1994 turbo wagon
So they are pretty much like the stock '92 tail lights huh (no orange reflector inside the housing)?
Jason
funny you said that..the pair i have do have an orange insert but it looks to be smaller than the usdm insert??. also doesn't seem to have the orange "glow" like my 94 lights
1994 SS "JDM-OEM"
1994 turbo wagon
1994 turbo wagon
update
i got the rear garnish today...definitly looks different than a usdm one.
1) the color of the panel is waaaaayyyy dark red, almost black. the color of the word legacy is the shade of red as the tailights
2) there is no "parking/brake" lens on the L&R sides, it is solid across.
the backing of the peice is like a usdm one, but the bulb holders have a rubber plug in it. took it out and even if i put a bulb in there, no light is getting through. there is a layer of paint or something on the inside
*EDIT*
so i thought this piece was weird cuz ive rechecked pics of some jdm rear garnishes and they look like usdm ones HHHmmmm
*EDIT*
1994 SS "JDM-OEM"
1994 turbo wagon
1994 turbo wagon
nope, its a stock peiece...it was just probably a weird trim package model. the car it came from was a japanese rs, but with an sti front lip, stock BBS's, etc
1994 SS "JDM-OEM"
1994 turbo wagon
1994 turbo wagon
Oh, so now you have a "rare" JDM body piece for your car. Well lody dah... (j/k)
That's definitely very cool!
Jason
Sorry to bump this from so long ago... but...
I found out what the rear garnish was from...
A D-Type Legacy RS-RA
ONLY THE D-TYPE the A-C types had the normal red garnish like the usdm ones.
So Brad... you lucky sob have an RS-RA D-type Rear Garnish...
*is going to grab my old garnish and split it and re-do it*
your rear lights/reflector?asc_up wrote:And a note about the JDM rear turn/brake lights.
I just took the orange reflector out of my USDM one's and it looks exactly the same...
Oh and it was free!! Hahaha.
did you put it in the oven for 3 min @ 250* to do this?
Actually... in the USDM tails, there is a reflector on the corner... OH AND this is post facelift only. Not pre.
But look at the very outside edge of your usdm tails and look at the reflector. Then look at Brads jdm tails...
Not reflector.
Not reflector.
Hahahaha I was just thinking to myself, "That orange piece probably created a certain beam pattern, because I remember Vikash talking about this in front turn signals..."
Damn...
Damn...
ah ha ha o snap.vrg3 wrote:It's not exactly the same, though. The orange dealie you took out was partly responsible for making the correct beam pattern. You should put it back.
i truly didn't see this coming vrg,
yeah spencer you better put it back
I didnt pull it out... I switched to EDM tails with rear fogs that were bright as f*ck... and looked cool.
No. I took off the tail lights, shoved some vice grips into the corner light area and ripped out the plastic orange reflector.SubaruNation wrote:your rear lights/reflector?asc_up wrote:And a note about the JDM rear turn/brake lights.
Hmmm I did this on my 91 SS.smh0101 wrote:Actually... in the USDM tails, there is a reflector on the corner... OH AND this is post facelift only. Not pre.
Not reflector.
Im only talking post facelift...
And you cant remove that reflector piece. Its into the plastic.
