car chugging when its not warm question?
LEAVINALEGACY93
Post by LEAVINALEGACY93 »
i started driving my 92 turbo 5spd before it was completely warmed up, and when i steped on the accelerator 1/2-1/3 the car was chugging like crazy with little power? it was almost like a vaccum line was hooked up wrong
then in a couple minutes the car was warmed up and had no chugging problem at all and drove perfect.
replace the coolant temp sensor.
boro
Post by boro »
I replaced mine and it still doesn't like to move when cold. Though I have terrible compression on two cylinders, so I guess I should shut up... :-D
LEAVINALEGACY93
changed air filter , plugs , fuel system cleaner , n it runs amazing now. a little to good i was driving 180kmh the other day and when i got home there is a crack in the coolant resovoir tank. jb welded good to go.
