injector wiring colors
jilo860
Post by jilo860 »
can anybody take a look and write down what the colors are on the injector plugs. my fsm dosent list them correctly, they show different colors. thanks
Are you looking for the wiring colors at the plugs?
Your FSM doesn't list them correctly? What MY is your legacy.
jilo860
Post by jilo860 »
its a 93 legacy ss. not sure of the my numbers.
heres what im working with, i unfortunatley have the fsm for a ej20g 92 legacy. all my other fsm's are in my external hd which is packed up (im moving)
The info I have matches the same colors with the non-turbo diagram at the injectors.
You can d/l the manual I'm using from my site
http://www.main.experiencetherave.com:8 ... ual_scans/
jilo860
Post by jilo860 »
yea thats where i got the fsm's from. my injector wires on the drivers side bank are different colors than listed tho. passenger side is fine.
more problems tho, check my other thread.
