The Unichip apparently has the ability to lift the cutoff point and
control boost.
If your exhaust was added after you had the UniChip fitted it may
need to be remapped to get the full benefit of the new exhaust.
Otherwise I am assuming that APS did everything else when they fitted
it as part of the service.
Cheers
Chris
--- In BC-BFLegacyWorks@y..., "dfullerton" <dfullerton@d...> wrote:
> Chris i have a dastek unichip do you think i will be ok with my mrt
system.
> or will i need a fuel cut defender
> ----- Original Message -----
> From: "Chris Bresnehan" <cbresnehan@g...>
> To: <BC-BFLegacyWorks@y...>
> Sent: Wednesday, March 28, 2001 11:25 PM
> Subject: [BC-BFLegacyWorks] Re: Re: Exhaust/mrt
> > Hi All,
> > I also have a full MRT 3inch s/steel system fitted to my 93
Liberty
> > RS Turbo and have to agree with Rod that is an excellent well
designed
> > system and fitted perfectly.
> > I opted for the system with the centre muffler so noise is not
that
> > much of a problem compared to a couple of friends of mine who
have a BPM
> GT
> > system and an AVO system on their WRX's.
> > My only probelm now is the factory fuel cut at 1bar as the turbo
> > spools up much quicker and produces boost easier especially when
combined
> > with the mods I have already done. Hopefully an aftermarket ECU
should fix
> > this problem plus extract a bit more power.
> > Cheers
> > Chris
> > > Date: Wed, 28 Mar 2001 08:51:40 +1000
> > > From: "Rod" <melrod@o...>
> > > Subject: Re: Re: Exhaust/mrt
> > > hi all,
> > > this mrt system is the one i have fitted to my 92 RS Liberty
Turbo,
> along
> > > with the rest of the 3" s/steel system (bar the rear muffler, i
used one
> > > ex
> > > wrx) The system is very well designed and yes the cat is in the
engine
> > > pipe
> > > section, as original, where the O2 senser is...........
> > > regards, rod.
> > To unsubscribe from this group, send an email to:
> > BC-BFLegacyWorks-unsubscribe@egroups.com
> > Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
We give away $70,000 a month! Come to iWin.com for
your chance to win!
http://us.click.yahoo.com/olMXHC/BJVCAA ... /X7OVlB/TM
UniChip was: Exhaust/mrt
dfullerton
Ok then i will sell my apexi electronic boost controller it comes with all
the pipes and manule and stuff it is not the latest one but it is still very
good i guess i do not need it now
To: <BC-BFLegacyWorks@yahoogroups.com>
Sent: Friday, March 30, 2001 4:48 AM
Subject: [BC-BFLegacyWorks] Re: UniChip was: Exhaust/mrt
> control boost.
> Cheers
> Chris
> system.
> > > Hi All,
> Liberty
> designed
> that
> have a BPM
> > GT
> combined
> should fix
> > > Cheers
> > > Chris
> > > > hi all,
> Turbo,
> > along
> used one
> > > > ex
> engine
> > > > pipe
> > > > regards, rod.
your chance to win!
> control boost.
> Cheers
> Chris
> system.
> > > Hi All,
> Liberty
> designed
> that
> have a BPM
> > GT
> combined
> should fix
> > > Cheers
> > > Chris
> > > > hi all,
> Turbo,
> > along
> used one
> > > > ex
> engine
> > > > pipe
> > > > regards, rod.
your chance to win!
